Re: "Don't ask me how I know..."
[Re: BSharp]
#796
07/15/03 03:20 PM
07/15/03 03:20 PM
Posts: 96,666 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
The hole in the plate between the scattershield and block goes on the proper side so the starter snout can be mounted thru that hole and engage with the flywheel. Get it right before mounting the tranny, ect. !
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: amxautox]
#797
07/15/03 03:22 PM
07/15/03 03:22 PM
Posts: 26,561 Santa Rosa, NOR*CAL.
Just Cameron
Starters can't be flipped upside down and mounted on the other side of the motor, don't ask Tom how he knows that.
[Re: Beeracuda]
#807
07/15/03 06:08 PM
07/15/03 06:08 PM
removing an oily four speed with bell housing can despite warnings about hand placement, lead to removal of finger tips, lots of blood and your mate passing out from the site of his (ex) fingers leading to further complications of concussion and a dented front fender....
#808
07/16/03 06:42 AM
07/16/03 06:42 AM
Posts: 4,768 Moved to N.E. Tennessee
GomangoCuda
An Msd 7 has enough power to make you hit your head on the hood and fall on your butt. Your hole arm will shake for at least 15 minutes.
[Re: GomangoCuda]
#809
07/16/03 09:15 AM
07/16/03 09:15 AM
Ignoring the dipstick in my very high mileage daily driver results in taking the bus to work.
Being told to shut up and mind my own business while a neighbor was about to have his 4x4 Ramcharger towed with a wheel lift type towtruck results in many hours of laughing while watching said neighbor trying to scrub 90W off his driveway from a broken differential.
They are right, POR 15 does not come off your hands.....nobody said anything about your face!
Accell supercoils explode if you leave the ignition on without the engine running for a couple of hours. An oil covered engine compartment is a pain in the but to clean up.
Driving 5 miles back home with a broken tie rod is possible, the loose tire will follow strait but only at less that 1 mph.
Very expensive NOS parking light lenses melt very easy when the wrong bulbs are installed behind them.
I also agree that carb cleaner burns like hell when you get it in your eyes.
As the subject says, dont ask me how i know these things.
#810
07/16/03 12:06 PM
07/16/03 12:06 PM
Replace all 30 year old brake lines when upgrading your brakes, unless you like scrubbing brake fluid off your driveway after testing your fancy new brakes for the first time.
#811
07/16/03 01:22 PM
07/16/03 01:22 PM
Posts: 1,381 Youngsville, NC
dem440c
Youngsville, NC
...it's a good idea to install the oil filter before priming the oil pump...
...put the valve covers back on before priming the oil pump...
...a box end wrench is not the tool of choice for installing tranny cooler lines...
...yes, you can put out an engine fire with a can of Mountain Dew...
...always get the core engine with all accessories and brackets attached; conversely, never try to mix'n'match big block accessories, brackets, and water pump housings from various vintages...
...while crimping the wiring connectors for the lights on your mechanical water temp gage, be careful not to slice through the sensor lead with the other end of your multi-function crimping tool...
...test your brand new water temp gage in a pot of boiling water before trusting it during cam break-in...
...not checking your oil for two months in a 200,000 mile engine results in large holes in the block...
...tuning around a massive vacuum leak just means you'll have to start the tuning process over when you finally fix the vacuum leak...
...30+ year old plastic is quite brittle...
...don't ask me how I know! I'll think of a few more later
[Re: dem440c]
#812
07/16/03 02:18 PM
07/16/03 02:18 PM
IF your not getting gas to your pick up truck but really need to get it home to fix it you can cut the top out of a gatorade bottle and fill it with gas and create a siphon flow mini gast tank by proping it up with the windshield wiper and using a piece of rubber hose. you can regulate the flow with a pair of vice grips and they also help to keep the rubber hose flowing into the top of your carb.
just dont go to fast and pray you dont have far to go.
Jason
