Re: Dana 60 questions, my plan.......
[Re: DoctorDiff]
#7747
12/14/03 11:21 PM
12/14/03 11:21 PM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
DrDiff....thanks for the info. by the way, how can i tell by looking at it if its a 60, a 60 HD, or a 61?? is the number cast into the webbing on the top or bottom side of the rearend?? thanks, CHIP
[Re: DoctorDiff]
#7750
12/15/03 10:04 PM
12/15/03 10:04 PM
an8sec70cuda
Doc....thanks for the info man, i preciate it!! one thing i am unsure of.....how can i identify the 61????
the owner pulls the parts at this junkyard, not myself. is there any particular year or model truck i can tell him to get the rear from and be certain itll be a Dana 60?? thanks, CHIP
[Re: an8sec70cuda]
#7751
12/15/03 11:09 PM
12/15/03 11:09 PM
Posts: 8,016 Polson, MT
DoctorDiff
Polson, MT
If you find an unmarked housing, you must either decode the BOM number stamped on the housing or take it apart, to detrermine if it is a Dana 60 or 61. Of course, Any ratios faster than 3.54 are give-aways. Unfortunately, there are 3.54 and 4.10 geared Dana 61s also.
Any housing with a "60" cast into the bottom right side web will be a Dana 60.
I recommend late 60's International, Dodge and Ford 3/4 ton pickups. Make sure the housing you choose is wide enough to be cut to your desired dimension and offset.
[Re: an8sec70cuda]
#7752
12/15/03 11:12 PM
12/15/03 11:12 PM
Posts: 1,771 St.Clair Shores MI.
tilt
St.Clair Shores MI.
Chip, I don't know if this helps you out but i crawled under a few at the local JY and a couple (ford and gmc) both were 3/4 tons and both had a "60" casted on the center section,i believe on the lower right hand side(on the web).Let's see if Dr. Diff can concour with this info.
Jeff
Ps they had no older Mopar trucks,Kinda funny HUH.
EDIT* there is also a "C 30255 on the upper right hand side*
68 CORONET R/T BEST MACHINE BUILT EFI'd TWIN TURBO(UP and RUNNING !!)
03 Mach1
