Re: Taking it to the next level? Wow!
[Re: Troy]
#77202
07/11/08 11:46 AM
07/11/08 11:46 AM
Posts: 1,711 USA
ECS
David Walden
David Walden
USA
Troy, Who are you having this imaginary sarcastic debate with? The side marker fender lights are not the area of concern. It is the valance and the valance lights that were in question as to whether they were installed prior to under coating!
[Re: cataclysm80]
#77203
07/11/08 11:47 AM
07/11/08 11:47 AM
Posts: 1,711 USA
ECS
David Walden
David Walden
USA
Ok, on this closer inspection, I'd believe it's road tar. So this would mean that the valance was either painted off the car or removed prior to undercoating, possibly for bumper installation. Correct?
Tav
[Re: ECS]
#77205
07/11/08 12:04 PM
07/11/08 12:04 PM
Posts: 4,165 Florida
cataclysm80
Tav
I wonder then why the process would be different for a barracuda?
It was previously mentioned that a 71 'cuda does have undercoating on the valance.
My 70 Challengers front bumper brackets definately have undercoating on them (and a lot of yellow paint under that [car is EF8 green]). Looks like the undercoating was applied after bumper installation.
The bumper was attached to the brackets as an assembly before installation correct?
Anyone know if the front valance was painted on or off the car? (rear valance was painted on car then removed and reinstalled later)
Tav
[Re: Troy]
#77211
07/11/08 02:57 PM
07/11/08 02:57 PM
Posts: 3,957 West Coast, CA
Troy
West Coast, CA
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
[Re: ECS]
#77212
07/11/08 03:00 PM
07/11/08 03:00 PM
cataclysm80
,But still wondering if the valance had to be removed to install another component like the bumper or something, OR if it was painted off the car. I just can't imagine why they'd remove the valance. Surely it wasn't removed just to keep undercoating off its backside. Tav
[Re: Troy]
#77213
07/11/08 03:14 PM
07/11/08 03:14 PM
cataclysm80
Take a look at these...
On the turn signal wiring, you can see undercoating on the plug, side marker housing and wiring harness.
Troy, I see the undercoating clearly on the turn signal harness. I didn't see any on your valance. Is it correct that there is no undercoating on your valance? Just checking.
Thanks Tav
[Re: Troy]
#77214
07/11/08 03:17 PM
07/11/08 03:17 PM
Troy
West Coast, CA
At times they say a picture is worth a thousand words... Sure is alot of paint on the fender where the valance butts up against it... ( I knew I had a picture of this some where )
[Re: ECS]
#77216
07/12/08 11:29 AM
07/12/08 11:29 AM
Troy
West Coast, CA
"You show a picture of the valance with the blackout paint as evidence of it being under coated!?!?" ....No, what I was trying to show is the lack of undercoating on the vallance.
"You also refer to “paint” on the tabs of the fender that connects to the valance but it looks more like primer and rust. (I can’t make out any paint at all.) As a matter of fact it looks like red oxide primer and the beginning edge/haze of brown paint just starting around the edge." ....What I was trying to say is the valance was off the car when it was painted. There is FT6 paint, clear as day under that speed nut.
I have a question about how the bumper brackets were installed. On my car I saw no undercoating on any of the front bumper brackets BUT there was no under coating under the brackets. How could this be???
[Re: ECS]
#77217
07/12/08 11:39 AM
07/12/08 11:39 AM
Posts: 27,485 So Cal
autoxcuda
So Cal
So if the front valence did NOT receive final paint in it's final position in the car, when in the process was it put back on the car?? When did it receive the blackout paint behind the valence? I see some bolt holes on the valance with exterior paint under them and some that were bolted when it got blacked out: ( edit- car in question is a T/A, those holes are for the chin spoilers.)
[Re: Troy]
#77219
07/13/08 03:06 AM
07/13/08 03:06 AM
Posts: 1,711 USA
ECS
David Walden
David Walden
USA
Troy, You have a T/A Challenger. The front valance was obviously handled differently than a Challenger without the front spoiler. I have not investigated that area or type of vehicle so I don't know why or how the differences developed within their assembly process. Some of your "oddities" might be explained within the T/A build procedures.
[Re: autoxcuda]
#77220
07/13/08 03:17 AM
07/13/08 03:17 AM
Posts: 1,711 USA
ECS
David Walden
David Walden
USA
The valance was painted on the car and removed to assist in ease of assembly for certain parts. The blackout was applied when it was removed (but painted) and re-installed after the other steps were completed. The core support blackout was applied sometime after the front valance was removed. Both black out steps were probably performed very close together.
[Re: ECS]
#77221
07/13/08 12:11 PM
07/13/08 12:11 PM
cataclysm80
The TA challenger front valance procedure should be the same as any other challenger. The front spoilers were placed in the trunk with instructions for dealer installation, thus no need for an assembly line change. The dealerships didn't always follow the instructions well during spoiler installation resulting in varied spoiler location. So far a copy of the factory instruction sheet has not surfaced.
For a spoiler bolt to have paint under it, that black on the valance must have been applied after the dealership installed the spoilers.
Tav
