1971 scamp 318 front end #770572
08/10/10 10:50 AM
08/10/10 10:50 AM
junkyardkid Offline OP
hey everyone!
they are not making a lot of parts for 71s anymore. i had to put in a 73 steering box and matching 73 pittman arm. then the center link didnt work so i got a nice centerlink from steves mopar in AK it was from a 74. common sense says idler arm should be 73 on up as well of course before all this i ordered a 71 front sway bar which hasnt arrives yet. a real mopar mechanic is doing the work, hes at a standstill. any helpful hints will be greatly appreciated
Re: 1971 scamp 318 front end [Re: junkyardkid] #770573
08/10/10 12:56 PM
08/10/10 12:56 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
What is the question?
Re: 1971 scamp 318 front end [Re: stumpy] #770574
08/10/10 01:28 PM
08/10/10 01:28 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
my head hurts.
Re: 1971 scamp 318 front end [Re: junkyardkid] #770575
08/10/10 01:35 PM
08/10/10 01:35 PM
N.Wilkesboro,NC
DusterKrazy Offline
DusterKrazy  Offline
N.Wilkesboro,NC
Does the car have a the '71 K-member or is it the '73 unit? If it is the '73 unit, you will need the '73 style sway bar. Otherwise I don't know what you are asking
Re: 1971 scamp 318 front end [Re: DusterKrazy] #770576
08/11/10 09:33 AM
08/11/10 09:33 AM
sorry, i didnt realize that i hadnt asked a question, been down with the flu. do i need to get a 73 idler arm? thanks
Re: 1971 scamp 318 front end [Re: junkyardkid] #770577
08/11/10 03:54 PM
08/11/10 03:54 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Yes, or you could have used a pre 73 pitman and kept our centerlink, but then a real mopar mechanic would have known that.
Don't be the exception.
Re: 1971 scamp 318 front end [Re: junkyardkid] #770578
08/11/10 04:02 PM
08/11/10 04:02 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
If he's a REAL Mopar mechanic he should NOt be at a standstill.
You can use the early sway bar. If there is interference with late model disc brakes mounted to the front, just shorten the end links on the bar.
Re: 1971 scamp 318 front end [Re: Jim_Lusk] #770579
08/11/10 04:12 PM
08/11/10 04:12 PM
North East Missouri
E
express Offline
express  Offline
E
North East Missouri
Doesn't the 73 up pitman arm & idler go in from the top of the center link?? If so all parts would need to be the same style.
72 down goes in from the bottom I know.
cny25421@centurytel.net 70 Duster Turbo Charged 79 Lil Red Express Bonded Locksmith
