My Hemi seems to be way down on power -Help!!! Update..
#770491
08/10/10 04:27 AM
08/10/10 04:27 AM
Posts: 258 Stockholm, Sweden
TomsCharger70
Stockholm, Sweden
Ive got an 40 some years old Pro Stock Hemi I run in my 1970 Charger. Comp. about 12.7:1 Nothing special about the crank (Kellog), the Nascar rods or Venolia Hi-Top pistons, other than they are on the heavy side... Heads are old Aluminium D4A Mullen ported heads. No clue about flow numbers.. Indy 426-I4-4 4500 high rise single four manifold that has been gasket ported. 1050 Dominator (#8896) converted to E85 I detuned the engine to be more street friendly, it came with a click for cam spec. camshaft, I thought it to be kinda on the wildside to run it on the street.. so I replaced it with this cam click for cam spec.OK, problem, or more disspointment came once I got the car to the track.. I really thought it would be faster.. I had hopes to run in the mid 11sec. Any ways.. I also have to write that I am a compleat novise when it comes to dragracing, so the 60 feet and reaction times could of course be better... This is my best run. Reaction: 0.76 60 foot: 1.83 1/8 speed: 91.1mph 1/8 time: 7.82 Trap speed: 116mph ET: 12.1235 The car is not a lightweight, my guess is that it will hit close to 4400lbs ontop of a scale Car itself has been built according to the Mopar Chassis book. Rear axel is a DR. Diff piece with 4.56:1 gears. Run 28" Racemaster Dragradial tires (325/50-15).. I have no video of launch to post at this time, but it felt like the tires did hook.. 727 trans built to take abuse. Converter is a Dynamic 9½" piece. OK, so the weird part is that the engine seems to compleatly lack power in first gear, it does how ever really feel to pull in second and third. Shiftpoint is at 7100rpm.. A/F is way on the rich side at WOT, about 12.2 A/F (Run E85 so its an ok number I guess) So my questions are: 1. Did I choke the life our of the engine with my choise of camshaft? (I do have plans on running the engine with Nitrous) 2. Or is this the 1/4 mile times to expect with a car that weighs as much as my Charger? 3. Im a compleat clot and should not be let any where near engines or tools... Thanks... /Tom
Re: My Hemi seems to be way down on power -Help!!!
[Re: TomsCharger70]
#770492
08/10/10 08:20 AM
08/10/10 08:20 AM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
I suspect the converter is the culprit. You have a heavy car w/ a large volume intake, a big set of heads, and relatively small cubic inches. I'm guessing it's around 438 cubic inches? Stock stroke crank? That motor wants to rev, like all hemis do, so it's gonna need a loose converter. Where does your current converter flash to? 116 MPH is enough to go mid 11s, just need to get it to 60 foot.
[Re: an8sec70cuda]
#770493
08/10/10 08:33 AM
08/10/10 08:33 AM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
Big ports small cam are one reason and coverter
home of the Sox and Martin Hemi Duster
[Re: HEMIFRED]
#770494
08/10/10 08:43 AM
08/10/10 08:43 AM
Posts: 952 Stockholm, Sweden
MrSixpack
Stockholm, Sweden
I agree with HEMIFRED. But I vote on #3 anyway Just kidding.
1970 Super Stock Challenger ex. Paul Rossi 1968 Dodge Dart GT 340 1968 Dodge Charger /6 3 speed manual 1966 Chrysler 300 Loaded 1968 Dodge Charger R/T 440
1968 Mini Cooper
[Re: HEMIFRED]
#770495
08/10/10 09:02 AM
08/10/10 09:02 AM
TomsCharger70
Stockholm, Sweden
-Yes, its a stock stroke engine, though has been bored .020 over, so its 430cid something? I need to check the converter flash. I also did the math and you are right, with the top end speed it should ET .5sec better and I would have it, if I wasnt such a clot at the starting line...
-Hmm, but what about the smaller cam in it right now? Its a cam designed to work best when running the engine on nitrous, so if I hooked it up with spray, would that wake it up more, or would that just be a "Bandaid" to the real problem?
The heads are heavily carved out, one could almost stick a fist and arm through the int./exhaust ports, so a stroker combo downstairs would make better use of the flow, right? Or just stick the old roller cam in it and converter that flashes higher???
Thanks and
/Tom
[Re: TomsCharger70]
#770496
08/10/10 09:11 AM
08/10/10 09:11 AM
Posts: 1,564 St. Clair Shores, Michigan
bigsbigelow
These guys need to know what rpm the converter stalls at. Put the trans in third gear, foot break it, and see what rpm the car tries to move. If you plan on running the car on nitrous, it will seem a little slow running it N/A. Can't have the best of both. I say check the converter stall, let us know where it is at, and I am willing to bet it is probably low for running your set up N/A but will be great when you spray it. BTW, spray won't be band-aid for you, if you already planned using. If you told PTC you planned on spray, they set your converter up for it. You may have too much gear for spray, though. Let us see what some others say. P.S. What rpm do you launch the car at?
[Re: TomsCharger70]
#770497
08/10/10 09:14 AM
08/10/10 09:14 AM
MrSixpack
Stockholm, Sweden
Tom, yes the nitrous is just a bandaid on a "not so good" package. With those huge ports, your airspeed will suffer bad, so bigger cam or smaller ports.
It's hard to build a (small) N/A high horsepower combination for both street cruising and strip.
1968 Mini Cooper
[Re: We The People]
#770501
08/10/10 09:58 AM
08/10/10 09:58 AM
Posts: 1,491 Oologah, Oklahoma
Big Squeeze
Oologah, Oklahoma
I agree with Chip......it makes enough power to go at least 11.40's, with the right converter.......so it's NOT cubic inches or the camshaft holding you back from reaching your goal.......
If you can't handle the truth, you're living a lie.......
[Re: TomsCharger70]
#770502
08/10/10 09:58 AM
08/10/10 09:58 AM
Posts: 642 New Jersey
Craig
New Jersey
When I got my car in 1982 the motor had almost all those same parts - Mullens ported alum heads, TRW pistons, 292 roller cam. When I had it rebuilt in 2000 the main changes were modern JE pistons, a 4.15 crank (477ci), and a Cam Motion 282 cam. It went from 650hp to 770hp, 550ft-lbs to 660ft-lbs, on the same dyno, with the crossram and carbs unchanged. I think those old pistons lose a lot compared to new, and those heads really want a stroker crank. Edit: I agree the converter may be a problem. Just remember the best one for this combo will likely be too loose if you later build a stroker.
67 Dart, 426 Hemi, 9.23/145mph, 3400lbs, footbraked, owned since 1982
[Re: HEMIFRED]
#770504
08/10/10 10:21 AM
08/10/10 10:21 AM
HEMIFRED
SOUTH JERSEY
this is their pro stock port.
[Re: TomsCharger70]
#770506
08/10/10 10:22 AM
08/10/10 10:22 AM
Posts: 397 North Carolina
jt1
North Carolina
How are you determining your A/F? 12.2:1 is way lean for E85, unless you're using the lambda value and calculating the A/F for gas. A normal value for E85 would be around 8:1, or .82 to .85 lambda.
John
[Re: jt1]
#770507
08/10/10 11:13 AM
08/10/10 11:13 AM
TomsCharger70
Stockholm, Sweden
John
John
The A/F number is calculated from the Lambda value. It doesnt matter if the gauge shows fuel or Ethanol A/F numbers, the numbers are calculated from the same Lambda value.. Its like saying the same thing but in different ways..
Ex. here is a chart..
Lambda = E85 A/F = Fuel A/F
0.700 6.832 10.290 0.710 6.930 10.437 0.720 7.027 10.584 0.730 7.125 10.731 0.740 7.222 10.878 0.750 7.320 11.025 0.760 7.418 11.172 0.770 7.515 11.319 0.780 7.613 11.466 0.790 7.710 11.613 0.800 7.808 11.760 0.810 7.906 11.907 0.820 8.003 12.054 0.830 8.101 12.201 0.840 8.198 12.348 0.850 8.296 12.495 0.860 8.394 12.642 0.870 8.491 12.789 0.880 8.589 12.936 0.890 8.686 13.083 0.900 8.784 13.230 0.910 8.882 13.377 0.920 8.979 13.524 0.930 9.077 13.671 0.940 9.174 13.818 0.950 9.272 13.965 0.960 9.370 14.112 0.970 9.467 14.259 0.980 9.565 14.406 0.990 9.662 14.553 1.000 9.760 14.700 1.010 9.858 14.847 1.020 9.955 14.994
/Tom
[Re: TomsCharger70]
#770508
08/10/10 11:17 AM
08/10/10 11:17 AM
TomsCharger70
Stockholm, Sweden
Hemifred* The number stamped on the heads seems to be 1758 (Sorry about the bad picture quality, I cant for the life of me find the larger original picture) To my knowledge this engine never ran as a supercharged engine. This is the engine from the Brooklyn Heavy Duster.. /Tom
[Re: TomsCharger70]
#770509
08/10/10 12:13 PM
08/10/10 12:13 PM
HEMIFRED
SOUTH JERSEY
if so then that's a n/a head unless the exhaust port was modified. this are large ports that's a fact. back then they didn't have flow benches like today not long after that did they start to close the exhaust port down to 3/4 of the size. I think they are working against you with the smaller cam
[Re: HEMIFRED]
#770510
08/10/10 02:31 PM
08/10/10 02:31 PM
TomsCharger70
Stockholm, Sweden
OK, so I guess I have two choices then concerning the engine.. 1. Keep it at stock stroke but use a high .750 lift roller cam and high stall converter to get the use of flow and power from what the heads can make.. Or... 2. Build a 540 cubic inch stroker bottom end and supercharge it and with that I could use the hyd. roller cam and may be even the Dynamic 9½ converter I have in the trans now... /Tom
