Re: My Hemi seems to be way down on power -Help!!!
[Re: TomsCharger70]
#770511
08/10/10 02:36 PM
08/10/10 02:36 PM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
OK, so I guess I have two choices then concerning the engine..
1. Keep it at stock stroke but use a high .750 lift roller cam and high stall converter to get the use of flow and power from what the heads can make..
Or...
2. Build a 540 cubic inch stroker bottom end and supercharge it and with that I could use the hyd. roller cam and may be even the Dynamic 9½ converter I have in the trans now...
/Tom
Just a converter change will likely get you right where you want to be.
[Re: TomsCharger70]
#770512
08/10/10 02:40 PM
08/10/10 02:40 PM
Posts: 952 Stockholm, Sweden
MrSixpack
Stockholm, Sweden
Or you and I can switch heads, mine are brand new never assemblied. New valves, springs, retainers etc. Then your old heads can find there way back in to my challenger once more
1970 Super Stock Challenger ex. Paul Rossi 1968 Dodge Dart GT 340 1968 Dodge Charger /6 3 speed manual 1966 Chrysler 300 Loaded 1968 Dodge Charger R/T 440
1968 Mini Cooper
[Re: TomsCharger70]
#770513
08/10/10 07:04 PM
08/10/10 07:04 PM
Posts: 2,578 sweden
1Fast340
sweden
Tom i saw you car at the track im sure i didnt see all your runs but the few i saw on saturday it looked like the car wasnt hooking up to good and maybe some shiftertrouble also if that helps you troubleshoot. im not an expert of anykind and im not very good at judging how a heavy dragradial car on leafsprings hooks after to much looking at my friends light nova on ET streets wich has fairly good 60´s very nice seing your car at the track finaly i know how long you have been working to get there,and im sure you will get it all sorted out with some time and patience
[Re: TomsCharger70]
#770514
08/18/10 05:00 PM
08/18/10 05:00 PM
Posts: 258 Stockholm, Sweden
TomsCharger70
Stockholm, Sweden
Little update... Checked what rpm on the converter stalls at. I got it up to about 3500Rpm before the rear tires got grip and started to push the car forward (3rd gear).. is this to low for the engine setup Im running??? Another problem: The engine also seems to "Bog" when I hit the throttle hard. Also a probable reason why my ET is not where it should be.. To cure the "bog" -Would a larger size squirter help? I dont want to change to many things at once... remeber Im a Noob! Thanks /Tom
[Re: TomsCharger70]
#770515
08/18/10 05:05 PM
08/18/10 05:05 PM
an8sec70cuda
That's not the stall. Put it in 3rd gear, get rolling at about 10 mph, mash the throttle wide open quickly and see what the tach jumps to. Do not hold it wide open, just a quick stab to see where the RPM flashes to. That will be your flash stall.
[Re: an8sec70cuda]
#770516
08/18/10 05:08 PM
08/18/10 05:08 PM
TomsCharger70
Stockholm, Sweden
I just realised that I did it wrong Need to try it again...
/Tom
[Re: TomsCharger70]
#770518
08/19/10 05:43 PM
08/19/10 05:43 PM
TomsCharger70
Stockholm, Sweden
Tried it again today, the converter flashes to 4500Rpm, seems OK for the combo, right? I wonder if the problem why my ride wont run the time slip it should, well not taking into account the driver -Me, is the carburetor... There is a serious "bog" when I hit the throttle hard. I changed squirters to the largest I have (QF # 55).. Seems that the acc. pump shot is just not enough.. The bog is really bad when rolling and hitting the throttle hard. The A/F gauge went up to 22.5 thats like leaner than He..ll.. From a stand still and if I ease into it kinda carefully, it will not bog, but easing in on the throttle when dragracing kinda goes against the whole idea of dragracing... Tried to brake it against the converter, but the tarmac was just to slippery, so the front wheels just started to slide, and when the front tires would hold, then the rear tires would just spinn with out traction... May be going up in main and secondary jet would help, but then again that would just suck, cause the engine is already running fat.. if I run it even more, then birds will start to drop down from the sky if they fly over my ride... Ooh, and I run my engine on E85, but tuning the carb and trying to get rid of issues should still be about the same.. /Tom
[Re: 1Fast340]
#770521
08/26/10 11:44 PM
08/26/10 11:44 PM
TomsCharger70
Stockholm, Sweden
have you checked that you realy get a pumpshot from the accpump? so its not just some crap stuck in it,also have yóu checked that you actualy get fuel to the accpumpwell? im thinking your not getting the fuel there..
that explains it atleast from what i saw at kjula i just thought you had a shifter problem or something other strange since i couldnt here what or if your engine did anything at the startingline with all the other cars beeing so much louder,that hemi is very quiet
No problems with the pump shoot, checked and tested... The shifter "problem" was not really any problem at al, it was just me messing about and acting like a compleat dork...
-Yes, the sound my Hemi makes, is to quiet.. The only way I know my engine is running in the stageing lane is to check the Rpm gauge.. Need to change out the Super Turbo mufflers, they are way to quiet...
..any ways... Went back to the Race track last weekend and I GOT MY 11sec TIME SLIP..
Reaction: 0.37 60foot: 1.77 1/8 speed: 92.5mph 1/8 time: 7.68 1/4 speed: 118mph 1/4 time: 11.91
I did some change in the carb setup. I changed out the squirter to the largest one I found, a squirter # 63. I also checked the engine timing and to my suprise it was only 30*, I raised it up to 36*
The carb "bog" is still there, though not as bad.. I also found out that if I ran the engine against the brakes and got the Rpm to about 2500 then it did not "bog"..
I also guess one reason for the "bad" 60 foot times is the rear tires, they are old and even though not used, I guess they lost some of that good grip they initially had.. so there is definately an issue with tire grip...
On a positive note, the top end Mph is higher this time around than the first. It went up from about 116mph to 118mph.. So the engine definately has to power to go mid 11sec times. I just need to get the car to 60foot better... My reactions times are also much better.. Actually on that 11.91sec run, my reaction time was the slowest of al 5 runs I did that day... The two runs before and two runs after, were just a hair over 12sec.
/Tom
Re: My Hemi seems to be way down on power -Help!!! Update..
[Re: TomsCharger70]
#770522
08/27/10 01:59 AM
08/27/10 01:59 AM
Posts: 58 Oak Lawn IL.
kosdart1
Oak Lawn IL.
I think you should put the old cam back in the engine...The new cam you have is killing the engine..the 119 ex.C/L for one,and if you are running stock rockers,you need the check the lift at the intake valve........Stock intake rockers lose about .100 lift.......you are chocking the intake side for flow,,and over scavaging what little fuel thats getting in there,,,,Yes I know the car is heavy,,,But I would try the old cam,,You have,,no cost to try this.....Hope this helps.....
