15x6 stamped wheel #770319
08/09/10 11:19 PM
08/09/10 11:19 PM
West Central Wi.
1969 HEMI R-T Offline OP
West Central Wi.
can someone tell me the the year of this wheel. P# is 2944149 date is 10/13 my book does'nt list this # in it! 15x6 3 rib& flat between the lug holes. but no markings between the lug holes
Kevin
HEMI,S ARE FOREVER!!!
Re: 15x6 stamped wheel [Re: 1969 HEMI R-T] #770320
08/10/10 12:00 PM
08/10/10 12:00 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
2944169 is an H wheel, I dont see a 149 wheel in my book, may be the Imperial wheel
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: 15x6 stamped wheel [Re: AZ_A12_BEE] #770321
08/10/10 07:05 PM
08/10/10 07:05 PM
West Central Wi.
West Central Wi.
thanks my book is the same as yours. I just double checked the wheel that is the # on there. the real (large H) wheels had no p# stamped on them, is that correct?
Kevin
Re: 15x6 stamped wheel [Re: 1969 HEMI R-T] #770322
08/11/10 10:26 AM
08/11/10 10:26 AM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Kevin
70 and 71 H wheels did get the part # and pentastar stamped on them by the valve stem
Re: 15x6 stamped wheel [Re: AZ_A12_BEE] #770323
08/11/10 02:39 PM
08/11/10 02:39 PM
Midwestern Indiana
duster2 Offline
duster2  Offline
Midwestern Indiana
I wonder if it is the 15 x 6 solid wheel , used on the big Chryslers. It is 4.5 bolt pattern , but no air gaps.
I have 8 of these that will be at the Nats for sale.... Don't have a pic right now.
Frank
Re: 15x6 stamped wheel [Re: duster2] #770324
08/11/10 06:39 PM
08/11/10 06:39 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Those solid wheels were used on the 71 Sport Fury GT . . . pretty damn rare I would think. . . .but then again, why would Mopar build a wheel that would hold the heat from the brakes ?? Not have any cooling ability ???? Strange happenings in the late 60's/early 70's !!
Cheers
Mark
Re: 15x6 stamped wheel [Re: a12rag] #770325
08/12/10 10:47 PM
08/12/10 10:47 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Cheers
Mark
The solid wheels where Imperial wheels
Re: 15x6 stamped wheel [Re: AZ_A12_BEE] #770326
10/20/10 08:47 PM
10/20/10 08:47 PM
Nebraska
N
no318 Offline
no318  Offline
N
Nebraska
I have a set of solid ones that are 4.5" bolt circle. I thought all imperial ones were 5".
Re: 15x6 stamped wheel [Re: AZ_A12_BEE] #770327
10/21/10 01:43 AM
10/21/10 01:43 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Most solid 15 x 6" wheels were originally used on C-bodies with full wheel covers (5 x 4 1/2" bolt pattern).
