T-Brake VS Foot Brake
#769161
08/08/10 09:54 PM
08/08/10 09:54 PM
Posts: 866 Winnipeg ,Mb. CA.
chryco
Winnipeg ,Mb. CA.
Some say a t-brake will improve 60' others same not much difference . My engine was originally built for a car with a four speed . I`m running a 'Glide with a 4600 stall converter. I think I`ll pick up with my combination with the brake leaving at higher RPM. No ? Opinions VERY Welcome ! Chryco
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: T-Brake VS Foot Brake
[Re: Cab_Burge]
#769166
08/08/10 10:11 PM
08/08/10 10:11 PM
Posts: 30,474 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
Your glide with a brake will get TREED by a 727/904 with a brake .. if he can hook-it.
I wouldn't bet money on that one
Well Old F..t ...I would !
[Re: 440Jim]
#769168
08/08/10 10:28 PM
08/08/10 10:28 PM
chryco
Winnipeg ,Mb. CA.
What is your combo? Power, weight, cam, heads, CID, etc.
That stall speed sounds low for a racing Powerglide application.
The alloy 557" Hemi was dyno`d at 874HP and 750ft/lbs , the car weighs 2750 on the line ,Bullet Racing Cams Int. 278@.050" / Exh. 284@.050 - .754"Int / .722"Exh.Comp Cams Roller lifters,Mopar Perf heads - Barton tweeked O ringed. RBRE 896 series S/S 2.250" Int. RBRE 896 series S/S 1.940" Exh.,it, has a light weight front half and has been back halfed with ladder bars and a floating 44" Dana 60 w/4.10 Stange gears, spool and axles and driveshaft w/ 1350 u-joints. I run 14.5/32/15* *Goodyears for rubber. The car has Wilwood discs all around , 12 point mild steel cage* . The front end including the bumper is glass , the doors and decklid also . The trans is a J.W. Perf. Glide ' with Ultra bell adapter , The Wheel flywheel , J.W. transbrake , and 4600 stall 9" converter. I`m using a Hurst Quarter Stick with pistol grip shifter also Hurst Linelock. Chryco
[Re: chryco]
#769169
08/08/10 10:32 PM
08/08/10 10:32 PM
dOc !
Florida STAYcation
....and NITRO furr fuel ?
[Re: 440Jim]
#769170
08/08/10 10:32 PM
08/08/10 10:32 PM
Posts: 3,456 Out West
408strokerdart
Out West
My thoughts exactly. Was the converter built for the application or purchased second hand? Is that actual stall speed as tested? Converter is 90% of making a glide work.
[Re: dOc !]
#769172
08/08/10 10:36 PM
08/08/10 10:36 PM
Posts: 8,165 Left Coast
BobR
Left Coast
Typical Mopar Rah, Rah B.S.
[Re: chryco]
#769174
08/08/10 10:50 PM
08/08/10 10:50 PM
chryco
Winnipeg ,Mb. CA.
Hey Jim Where does your`s stall at ?
[Re: dOc !]
#769175
08/08/10 10:51 PM
08/08/10 10:51 PM
Posts: 1,162 s e mich
ro23car
s e mich
are you related to cuck wescott?
[Re: BobR]
#769177
08/08/10 11:04 PM
08/08/10 11:04 PM
dOc !
Florida STAYcation
"Bart Simpson MOONING the Mad-Man"
[Re: chryco]
#769179
08/08/10 11:08 PM
08/08/10 11:08 PM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
It's right around 5500. Mine should be a little higher but my sixty is a little less than it should be too.
