T-Brake VS Foot Brake #769161
08/08/10 09:54 PM
08/08/10 09:54 PM
Winnipeg ,Mb. CA.
chryco Offline OP
chryco  Offline OP
Winnipeg ,Mb. CA.
Some say a t-brake will improve 60' others same not much difference . My engine was originally built for a car with a four speed . I`m running a 'Glide with a 4600 stall converter. I think I`ll pick up with my combination with the brake leaving at higher RPM. No ?
Opinions VERY Welcome !
Chryco
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: T-Brake VS Foot Brake [Re: chryco] #769162
08/08/10 10:00 PM
08/08/10 10:00 PM
Cab_Burge Online work
Cab_Burge  Online Work
the only way I know to find out is to put the pedal on the floor and let the button go, compare the times slips and see
Re: T-Brake VS Foot Brake [Re: chryco] #769163
08/08/10 10:01 PM
08/08/10 10:01 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Your glide with a brake will get TREED by a 727/904 with a brake .. if he can hook-it.
Re: T-Brake VS Foot Brake [Re: dOc !] #769164
08/08/10 10:04 PM
08/08/10 10:04 PM
I wouldn't bet money on that one
Re: T-Brake VS Foot Brake [Re: Cab_Burge] #769165
08/08/10 10:05 PM
08/08/10 10:05 PM
Winnipeg ,Mb. CA.
chryco Offline OP
chryco  Offline OP
Winnipeg ,Mb. CA.
That`s the plan next time out ...WOOOOHOOOOOO!!!!!!!!
Re: T-Brake VS Foot Brake [Re: Cab_Burge] #769166
08/08/10 10:11 PM
08/08/10 10:11 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
Well Old F..t ...I would !
Re: T-Brake VS Foot Brake [Re: chryco] #769167
08/08/10 10:13 PM
08/08/10 10:13 PM
NC
440Jim Offline
440Jim  Offline
NC
What is your combo? Power, weight, cam, heads, CID, etc.
That stall speed sounds low for a racing Powerglide application.
Re: T-Brake VS Foot Brake [Re: 440Jim] #769168
08/08/10 10:28 PM
08/08/10 10:28 PM
Winnipeg ,Mb. CA.
chryco Offline OP
chryco  Offline OP
Winnipeg ,Mb. CA.
The alloy 557" Hemi was dyno`d at 874HP and 750ft/lbs , the car weighs 2750 on the line ,Bullet Racing Cams Int. 278@.050" / Exh. 284@.050 - .754"Int / .722"Exh.Comp Cams Roller lifters,Mopar Perf heads - Barton tweeked O ringed. RBRE 896 series S/S 2.250" Int. RBRE 896 series S/S 1.940" Exh.,it, has a light weight front half and has been back halfed with ladder bars and a floating 44" Dana 60 w/4.10 Stange gears, spool and axles and driveshaft w/ 1350 u-joints. I run 14.5/32/15* *Goodyears for rubber. The car has Wilwood discs all around , 12 point mild steel cage* . The front end including the bumper is glass , the doors and decklid also . The trans is a J.W. Perf. Glide ' with Ultra bell adapter , The Wheel flywheel , J.W. transbrake , and 4600 stall 9" converter. I`m using a Hurst Quarter Stick with pistol grip shifter also Hurst Linelock.
Chryco
Re: T-Brake VS Foot Brake [Re: chryco] #769169
08/08/10 10:32 PM
08/08/10 10:32 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
....and NITRO furr fuel ?
Re: T-Brake VS Foot Brake [Re: 440Jim] #769170
08/08/10 10:32 PM
08/08/10 10:32 PM
Out West
408strokerdart Offline
Out West
My thoughts exactly. Was the converter built for the application or purchased second hand? Is that actual stall speed as tested? Converter is 90% of making a glide work.
Re: T-Brake VS Foot Brake [Re: 408strokerdart] #769171
08/08/10 10:35 PM
08/08/10 10:35 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Not sure if you changed the motor from the prior owner but my records show peak tq is 5400 rpm. You need to have the flash about 100 rpm OVER the peak tq and this is especially true with a glide (taller 1st gear). Loosen that thing up some!
Re: T-Brake VS Foot Brake [Re: dOc !] #769172
08/08/10 10:36 PM
08/08/10 10:36 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Typical Mopar Rah, Rah B.S.
Re: T-Brake VS Foot Brake [Re: Bigcube] #769173
08/08/10 10:49 PM
08/08/10 10:49 PM
Winnipeg ,Mb. CA.
chryco Offline OP
chryco  Offline OP
Winnipeg ,Mb. CA.
Nope didn`t change anything since the day Tweety picked it up from Barton`s . That`s the converter I got from JW when I bought the Glide c/w Brake converter and "wheel" all from the numbers I gave them .
Re: T-Brake VS Foot Brake [Re: chryco] #769174
08/08/10 10:50 PM
08/08/10 10:50 PM
Winnipeg ,Mb. CA.
chryco Offline OP
chryco  Offline OP
Winnipeg ,Mb. CA.
Hey Jim
Where does your`s stall at ?
Re: T-Brake VS Foot Brake [Re: dOc !] #769175
08/08/10 10:51 PM
08/08/10 10:51 PM
s e mich
ro23car Offline
ro23car  Offline
s e mich
are you related to cuck wescott?
Re: T-Brake VS Foot Brake [Re: ro23car] #769176
08/08/10 10:55 PM
08/08/10 10:55 PM
Winnipeg ,Mb. CA.
chryco Offline OP
chryco  Offline OP
Winnipeg ,Mb. CA.
We don`t talk about that end of the family. LOL !!!!
Re: T-Brake VS Foot Brake [Re: BobR] #769177
08/08/10 11:04 PM
08/08/10 11:04 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
"Bart Simpson MOONING the Mad-Man"
Re: T-Brake VS Foot Brake [Re: BobR] #769178
08/08/10 11:04 PM
08/08/10 11:04 PM
Kokomo, IN
540dust Offline
540dust  Offline
Kokomo, IN
I agree, too tight, I run about 6000.
Re: T-Brake VS Foot Brake [Re: chryco] #769179
08/08/10 11:08 PM
08/08/10 11:08 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Hey Jim
It's right around 5500. Mine should be a little higher but my sixty is a little less than it should be too.
Re: T-Brake VS Foot Brake [Re: Bigcube] #769180
08/08/10 11:11 PM
08/08/10 11:11 PM
Winnipeg ,Mb. CA.
chryco Offline OP
chryco  Offline OP
Winnipeg ,Mb. CA.
Hey Jim
WOW ! 4600 sure does seen tight .
