Tranny cooler lines #767866
08/07/10 05:38 PM
08/07/10 05:38 PM
ohio
U
Unknown_element Offline OP
U
ohio
what does nhra accept? What are you guys running?
Re: Tranny cooler lines *DELETED* [Re: Unknown_element] #767867
08/07/10 05:51 PM
08/07/10 05:51 PM
Communist New York State, Comi...
W
We The People Offline
W
Post deleted by tboomer
Re: Tranny cooler lines [Re: We The People] #767868
08/07/10 06:01 PM
08/07/10 06:01 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
RUBBER must be an approve brand otherwise copper, steel or steel braided
home of the
Sox and Martin Hemi Duster
Re: Tranny cooler lines [Re: HEMIFRED] #767869
08/07/10 06:54 PM
08/07/10 06:54 PM
ohio
U
U
ohio
stock my lines were 3/8 to the radiator. I looked on summit's website but couldnt come up with a 3/8 inverted flare to an.
Also, what size an are you running? -4 or -6?
Thanks guys!
Re: Tranny cooler lines [Re: Unknown_element] #767870
08/07/10 07:08 PM
08/07/10 07:08 PM
W
W
I wish I could help with sizes, but I cant remember, I made them years ago. I believe I cut and made the line ends at the AN cooler... so there is no AN to flare.
do a search on google for AN fittings, there was a few good sites where you could get all kinds of obscure weird fittings. I do remember it being a pain in the but. Good luck
Re: Tranny cooler lines [Re: Unknown_element] #767871
08/07/10 07:12 PM
08/07/10 07:12 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The original 727 lines were 5/16" which is equivalent to AN5 but AN5 is an orphan size so AN6 is the preferred size, AN4 is too small.
Re: Tranny cooler lines [Re: Unknown_element] #767872
08/07/10 07:37 PM
08/07/10 07:37 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
I am running -6.
Re: Tranny cooler lines [Re: Leigh] #767873
08/07/10 07:53 PM
08/07/10 07:53 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
I bought a BIG roll of 3/8 alum line some years back and have used that .. it is lite and disapates heat well. Just use the high pressure FI hose with the proper clamps ...
Re: Tranny cooler lines [Re: Unknown_element] #767874
08/08/10 12:02 AM
08/08/10 12:02 AM
I use AN male nipples 37 degree flare to pipe male fittings(different sizes, # 6 to #12 and in between) all the time, is this what your calling inverted flare? If so you will need the proper size nut, collar and flaring tool for the size you want to use If you want to use AN stainless covered hose make sure and order teflon lined hose, not neopreme
Re: Tranny cooler lines [Re: Cab_Burge] #767875
08/08/10 12:07 AM
08/08/10 12:07 AM
fullmetaljacket Offline
I've used copper hard line flared at the ends for the last 20 years and no issues. It gets rid of heat along route as well.
Re: Tranny cooler lines [Re: fullmetaljacket] #767876
08/08/10 06:01 PM
08/08/10 06:01 PM
ohio
U
U
ohio
here's what i came up with.
From the radiator im going to use the inverted flare to -4 an, -4 to -6 reducer, then -6 to the tranny, -6 to -4 reducer, -4 to 1/8npt into the tranny.
Sound good? Im starting to think 3/8 alum line would be easier!
Got a link to that website with all the crazy oddball fittings?
Re: Tranny cooler lines [Re: Cab_Burge] #767877
08/08/10 06:04 PM
08/08/10 06:04 PM
ohio
U
U
ohio
yes, inverted flare or 37 degree flare, ive always called it inverted flare. Where's a good place to get the teflon line hose at ? Thanks!!
Re: Tranny cooler lines [Re: Unknown_element] #767878
08/08/10 06:49 PM
08/08/10 06:49 PM
I buy some AN supplys from Summit and some from G&J Aircraft Surplus, 909-986-6534, in CA. G&J use to have (I haven't been to there store in quite a while, 15 YRS or so) a lot of surplus AN hoses in all sizes and lengths and linings They where very reasonably priced also Do you know if the pipe threads in the radiator and the outlet size on the cooler lines from the tranny are 1/8 pipe or 1/4 inch pipe thread? I think you can buy double male nipple reducers from 1/8 pipe to both #4 and #6 AN, if I remember correctly the trans outlet pressure to the radiator is under 20 lbs so pressure is not a issue, the tranny fluid temps are the reason for using Teflon line stainless hose
Re: Tranny cooler lines [Re: Cab_Burge] #767879
08/08/10 06:52 PM
08/08/10 06:52 PM
KY
juicedcuda Offline
juicedcuda  Offline
KY
I use -6 stainless braided line with the aluminum AN hose ends.
1970 Plymouth 'Cuda 1970 Plum Crazy "Gold Duster" 1973 Gold Duster
Re: Tranny cooler lines [Re: Cab_Burge] #767880
08/08/10 10:35 PM
08/08/10 10:35 PM
ohio
U
U
ohio
Im still using the stock radiator. 99 dakota, the cooler lines run to the radiator via 3/8 line. So i have to get inverted flare to an at the radiator. As far as the tranny, yes its 1/8 npt. I wish i could find some 3/8 inverted flare to -6 and 1/8 npt to -6, ill call that place tomarrow and do some hunting around. Thanks for the reply's!!!
Re: Tranny cooler lines [Re: Unknown_element] #767881
08/08/10 10:45 PM
08/08/10 10:45 PM
If you have a hydraulic hose supply store nearby they use 37 degree fittings also Most of there stuff is intended for high pressure and hot All of the hydraulic fittings I have bought are steel, no aluminum unless you ask for it and then they have to order them
Re: Tranny cooler lines [Re: Cab_Burge] #767882
08/09/10 10:31 AM
08/09/10 10:31 AM
ohio
U
U
ohio
Anybody have a good place to buy teflon lined braided stainless from?
Re: Tranny cooler lines [Re: Unknown_element] #767883
08/09/10 11:07 AM
08/09/10 11:07 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Cab, Russell hose is rated to 350 degrees. I can't speak for the generic stuff. Check out this chart. Thanks Russell spec page
Re: Tranny cooler lines [Re: Leigh] #767884
08/09/10 11:32 AM
08/09/10 11:32 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Re: Tranny cooler lines [Re: WILD BILL] #767885
08/09/10 11:43 AM
08/09/10 11:43 AM
ohio
U
U
ohio
Thanks bill!!!
Im going to go with the russel proflex hose.
For 3/8 inverted flare the thread is 11/16? I havent got a pitch gauge on it yet.
5/8-18 i belive is correct
