Re: Tranny cooler lines
[Re: We The People]
#767868
08/07/10 06:01 PM
08/07/10 06:01 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
RUBBER must be an approve brand otherwise copper, steel or steel braided
home of the Sox and Martin Hemi Duster
[Re: Unknown_element]
#767871
08/07/10 07:12 PM
08/07/10 07:12 PM
Posts: 25,949 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The original 727 lines were 5/16" which is equivalent to AN5 but AN5 is an orphan size so AN6 is the preferred size, AN4 is too small.
[Re: Cab_Burge]
#767877
08/08/10 06:04 PM
08/08/10 06:04 PM
Posts: 89 ohio
Unknown_element
ohio
I use AN male nipples 37 degree flare to pipe male fittings(different sizes, # 6 to #12 and in between) all the time, is this what your calling inverted flare? If so you will need the proper size nut, collar and flaring tool for the size you want to use If you want to use AN stainless covered hose make sure and order teflon lined hose, not neopreme
yes, inverted flare or 37 degree flare, ive always called it inverted flare. Where's a good place to get the teflon line hose at ? Thanks!!
#767878
08/08/10 06:49 PM
08/08/10 06:49 PM
Posts: 43,284 Bend,OR USA
Cab_Burge
I buy some AN supplys from Summit and some from G&J Aircraft Surplus, 909-986-6534, in CA. G&J use to have (I haven't been to there store in quite a while, 15 YRS or so) a lot of surplus AN hoses in all sizes and lengths and linings They where very reasonably priced also Do you know if the pipe threads in the radiator and the outlet size on the cooler lines from the tranny are 1/8 pipe or 1/4 inch pipe thread? I think you can buy double male nipple reducers from 1/8 pipe to both #4 and #6 AN, if I remember correctly the trans outlet pressure to the radiator is under 20 lbs so pressure is not a issue, the tranny fluid temps are the reason for using Teflon line stainless hose
[Re: Cab_Burge]
#767879
08/08/10 06:52 PM
08/08/10 06:52 PM
Posts: 761 KY
juicedcuda
KY
I use -6 stainless braided line with the aluminum AN hose ends.
1970 Plymouth 'Cuda
1970 Plum Crazy "Gold Duster"
1973 Gold Duster
[Re: Cab_Burge]
#767880
08/08/10 10:35 PM
08/08/10 10:35 PM
Posts: 89 ohio
Unknown_element
ohio
Im still using the stock radiator. 99 dakota, the cooler lines run to the radiator via 3/8 line. So i have to get inverted flare to an at the radiator. As far as the tranny, yes its 1/8 npt. I wish i could find some 3/8 inverted flare to -6 and 1/8 npt to -6, ill call that place tomarrow and do some hunting around. Thanks for the reply's!!!
#767883
08/09/10 11:07 AM
08/09/10 11:07 AM
Posts: 5,991 Anoka County, MN
Leigh
Anoka County, MN
Anybody have a good place to buy teflon lined braided stainless from?
Cab, Russell hose is rated to 350 degrees. I can't speak for the generic stuff. Check out this chart. Thanks Russell spec page
[Re: WILD BILL]
#767885
08/09/10 11:43 AM
08/09/10 11:43 AM
Posts: 89 ohio
Unknown_element
ohio
Thanks bill!!! Im going to go with the russel proflex hose. For 3/8 inverted flare the thread is 11/16? I havent got a pitch gauge on it yet. 5/8-18 i belive is correct
