What is 1 lb. of boost worth?? #767431
08/07/10 06:28 AM
08/07/10 06:28 AM
Circleville, Ohio
E
Evil67 Offline OP
Evil67  Offline OP
E
Circleville, Ohio
What would 1 pound of boost be worth on my setup (1 lb = ?? HP)
440 approx 450 HP - 9.5 to 1
all iron with ported head
Blow thru - 88mm garrett
Former Username - 71Cuda
Current Ride: 1967 Dart - 340
Re: What is 1 lb. of boost worth?? [Re: Evil67] #767432
08/07/10 08:14 AM
08/07/10 08:14 AM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
on my iron [346]head it was about 40HP.i have to dbl check.mine flow 280/180 at .600lift,my cam is .646/.631 lift.your result may very.it could be + or - 10hp of that depending on the head.
Re: What is 1 lb. of boost worth?? [Re: blownzoom440] #767433
08/07/10 09:46 PM
08/07/10 09:46 PM
Amarillo, Tx
daithi2 Offline
daithi2  Offline
Amarillo, Tx
it really depends on where your putting that 1psi on the turbos map. and the compexity of the setup, thier too many varibles to say really what you would expect, also you could dyno the exact same day exact same setup and see a 20hp difference or more.
heres a couple of my expierances
srt4 stock turbo 20psi 294hp
srt4 stock turbo 22psi 303hp
srt4 .50 trim 22psi 391hp
srt4 .50 trim 24psi 429hp
srt6 16psi 287hp
srt6 17-18psi 310hp
cummins 70psi 814hp
cummins 72psi 820hp
cummins 75psi 855hp
cummins 80psi 909hp
47 Dodge - turbocharged 493" 05 SRT6 - Only 10 second and fastest SRT-6
Re: What is 1 lb. of boost worth?? [Re: daithi2] #767434
08/07/10 11:21 PM
08/07/10 11:21 PM
IN
ahy Offline
ahy  Offline
IN
As a ballpark way to think about it, standard atmospheric pressure is 14.7 psi. Add on PSI with boost and you add about 7% to air density and power. If you start with 450 HP 1 psi gets you 7% or 30 more hp.
Re: What is 1 lb. of boost worth?? [Re: Evil67] #767435
08/07/10 11:32 PM
08/07/10 11:32 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
1 pound of boost would be worth about 20% of the actual 5 pounds more boost you know you want to add. You say 1 now......
Re: What is 1 lb. of boost worth?? [Re: Duner] #767436
08/26/10 05:27 AM
08/26/10 05:27 AM
Converse IN
oldyellerrt Offline
oldyellerrt  Offline
Converse IN
That's how it starts. I'll only do 1! next thing you know your at 22, and looking for more! That's where the term boostaholic comes from, I think!
Re: What is 1 lb. of boost worth?? [Re: oldyellerrt] #767437
08/26/10 10:44 AM
08/26/10 10:44 AM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
Unfortunately the power increase vs boost pressure equation isn't linear. The more boost you add, the less you gain per pound of boost added. I went from 10 psi of boost to 18 psi of boost - and on my combo it only gained roughly 100 hp.
Re: What is 1 lb. of boost worth?? [Re: Duner] #767438
08/26/10 02:25 PM
08/26/10 02:25 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Dropping from 17 psi to 8 psi cost me 200 hp. I also dropped a little alky spray when I did that so it factors in a wee bit too.
- Stu Harmon
Re: What is 1 lb. of boost worth?? [Re: feets] #767439
08/26/10 03:46 PM
08/26/10 03:46 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
I was just boost stacking it into a zero gain.
With my single T4 .96 A/R hot side and full 3" exhaust system - it simply can't get any more thru it and I think it's trying to choke it off at speed. I gots lot of stuff go fix before it'll go any faster.
Re: What is 1 lb. of boost worth?? [Re: Duner] #767440
08/26/10 03:55 PM
08/26/10 03:55 PM
Ontario, Canada
rtspeeddemon Offline
Ontario, Canada
WOW...
I dyno 520 RWHP at 8 lbs boost and 690 at 14 lbs boost. On my set-up i'm not dropping off at all, however haven't pushed it to 18 lbs boost either... yet :-)
Re: What is 1 lb. of boost worth?? [Re: rtspeeddemon] #767441
08/26/10 04:02 PM
08/26/10 04:02 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
I be trying to push it thru a straw.
I probably didn't have enough fuel for it either.
I guess I should only expect so much from 24# injectors? LOL
Re: What is 1 lb. of boost worth?? [Re: Duner] #767442
08/26/10 10:43 PM
08/26/10 10:43 PM
Motor City
Shaker223 Offline
Shaker223  Offline
Motor City
last I checked, 1 lb of boost is still worth 1 lb of boost.
Re: What is 1 lb. of boost worth?? [Re: Shaker223] #767443
08/26/10 11:21 PM
08/26/10 11:21 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I would think you'd also need to take into account, how much hp you spend to make that extra boost. Extra backpressure on a turbo set for higher boost and extra drag for turning a higher geared supercharger.
Re: What is 1 lb. of boost worth?? [Re: Shaker223] #767444
08/27/10 09:02 AM
08/27/10 09:02 AM
Ontario, Canada
Ontario, Canada
....OR with the high cost of parts, labour etc likely every lb of boost is costing us around $2,000 LOL
