Re: proportioning valve
[Re: wireweld]
#767119
08/06/10 10:20 PM
08/06/10 10:20 PM
RapidRobert
4 wheel discs! yeah I'm fixin to try that myself mainly cause of all the naysayers ![](/ubbthreads/images/graemlins/apimp.gif) . As you know the M/C half next to the firewall goes to the front discs and the other half to the rear. I get the "metering" and "proportioning" functions mixed up & it'd be nice to keep the warning light but if there is no residual pressure in the disc system (check the M/C, stick a drill bit into the brass seats) I'd actually try it as is & see how it acts. I have a 65 Dart w 74 dart discs (semi met pads) up front w 10" drums w stock linings in the rear and I kept the stock (9" drum splitter) & no probs around town and on the interstate but no panic stops (wet or dry) as of yet. I'd experiment and go from there. Holler how it does
[Re: wireweld]
#767120
08/06/10 10:35 PM
08/06/10 10:35 PM
Posts: 18,160 Mass
DAYCLONA
Mass
Ed,....on a 4 wheel disc brake set-up if you sized the calipers right (fluid volume wise front to rear) you can eliminate the proportioning valve or distribution block that was in your system,....you can Tee the front line off to each front wheel, the rear line can come directly off the master to the rear....
If you have access to/ or purchase a hydraulic rated gauge that goes up to 2000 psi, after bleeding your system, you can test the pressure bias of the front vs the rear, and wheel to wheel, to know exactly what your system is produceing,....look for a minimum 60/40 to a maximum 70/30 front/rear prefered bias ratio so that your vehicles braking is optimized
Mike
[Re: DAYCLONA]
#767121
08/07/10 12:37 AM
08/07/10 12:37 AM
Posts: 7,506 Az
Crizila
Az
Mike
That brake bias is on the money - as long as all 4 tires are the same size. I would suggest adding an adjustable porportioning valve any time you make changes to the stock brake system. You will be very lucky if you change to front or 4 wheel discs and hit the necessary bias correctly for your set up ( no matter what the brake salesman is telling you ). Of course you won't know until you have to make a panic stop ![](/ubbthreads/images/graemlins/bondo.gif)
Fastest 300
[Re: wireweld]
#767123
08/07/10 10:58 AM
08/07/10 10:58 AM
Posts: 211 ILL
Greentween
ILL
Yes. I believe the Dr Diff rear kit uses the small diameter piston caliper from Ford, so you gut your prop valve so it turns into a distribution block. I'm using the Summit rear kit which is that same caliper and thats what I did. Rear dosent lock up early on mine, but I have OEM slider calpiers up from (Large pistons).
I used the OEM prop valve (gutted) so the stock lines would bolt up. On the prop valve there is a large nut. Open that nut and a spring and rubber disk should come out. Removing those will make the rear line straight thru like a distribution block.
You should find out if the MC is for drum rear. If so, there may be a residual valve in the rear port that maybe you can remove.
Residual valve holds some pressure in the line to keep the drum brakes expanded a little. You dont need that with disc calipers.
