Re: The Mark Williams axle myth?
[Re: Challenger 1]
#766805
08/07/10 02:34 PM
08/07/10 02:34 PM
Posts: 8,165 Left Coast
BobR
Left Coast
I called Mark Williams several years ago to order some steel caps for the 8 3/4, I ended up asking them about their axle splines and why it is different. The rep I talked to said that they make both spline angles now, 30 and 45 degree
![](/ubbthreads/images/graemlins/iagree.gif) more info. MW 35 spline 45 deg pressure angle is 3% stronger than stock Dana 35 spline 30 deg. Put a Moser next to Williams product. NO comparison.
MW and Moser are not even in the same leaque, not even close. Moser products are fine for lower HP cars, but are hardly "hi performance"
MW stuff is way more advanced...and way better.
I have a Moser dana 60 in my street car and my race cars have all MW. I wouldn't trust my race car and my life to anything less.
There a reason MW cost more.
Well that's because you are a real racer. I don't know of any high HP cars running Moser anything. I get crapped on almost every time I use the "real racer" moniker but real racers know what I mean.
[Re: BobR]
#766806
08/08/10 02:15 AM
08/08/10 02:15 AM
Posts: 2,586 Illinois, Indiana, Louisiana
ProStDodge
Never found MW to have a performance advantage over Moser. I snapped the flange off a MW Dana 60 axle - called them and found a single axle cost more than a new set from Moser. Never have I broken a Moser axle, I can't say that about a MW. Maybe I'm not a real racer.
I am just thank full it was on the burnout, instead of on a full launch or at the top end. As it were, I only had to REPLACE a rim, tire, and rear 1/4 panel.
[Re: ProStDodge]
#766807
08/08/10 07:30 AM
08/08/10 07:30 AM
Posts: 6,295 U.S.
moparniac
U.S.
people who use the term "Real" racers are azzholes....... I bet they were "Real" racers from day one huh!
Mopar Performance
[Re: ProStDodge]
#766808
08/08/10 09:03 AM
08/08/10 09:03 AM
Posts: 2,172 Ohio
theclutcher
Ohio
Any other details about that axle? Age, mods, beyond warranty? Masterline or High Torque axles? Thanks
[Re: DoctorDiff]
#766810
08/08/10 12:26 PM
08/08/10 12:26 PM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
What I have is a 9" Ford with MW axles and I assume a MW spool. I have too much gear in the car and was thinking about getting a new 3rd member set up so I would have a spare with less gearing. The 3rd members from MW are $1000 more than Strange or Moser on comparable options. I was just curious to see if it was true that the MW axles wouldn't fit in any other spools. Thanks for all the info.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
