Fuel pump push rod... #766302
08/05/10 07:19 PM
08/05/10 07:19 PM
Portland, Or.
Bee4spd Offline OP
Bee4spd  Offline OP
Portland, Or.
I've been having some fuel delivery issues recently. First I found that all of my rubber fuel lines had jellied after a recent fuel up. Replaced all of them with Aeroquip push lock stuff. Go to start the thing and it won't start. So I check for fuel delivery, no go, buy a new Holley 110 mechanical pump (figuring the old Carter was dead). Check for fuel delivery again and no go! Use a siphon pump to see if line was blocked, it wasn't. Finally pulled the fuel pump push rod all the way out. It measures 3.218 inches, I've read that 3.242 inches is spec. Would this -.024 inches be enough to cause problems?
Thankyou in advance,
Brian
Re: Fuel pump push rod... [Re: Bee4spd] #766303
08/05/10 07:25 PM
08/05/10 07:25 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
What had been posted on Moparts and I saved;
PN: P5249569 (kit with a pipe plug on a card)
COST: $12. Local mopar dealer
LENGTH: 3.210
DIAMETER: .435
REDUCED END DIA: .415
REDUCED END LENGTH: .680
The rod is symmetrical on first install after that keep the cam end to the cam.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Fuel pump push rod... [Re: amxautox] #766304
08/05/10 07:49 PM
08/05/10 07:49 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Figure a way to SAFELY determine if the eccentic cup/washer the moves the push rod is causing movement. I have seen the bolt that holds it come loose causing it to not activate the push rod.
Careful, your character's showing!
Re: Fuel pump push rod... [Re: mopar346] #766305
08/05/10 09:03 PM
08/05/10 09:03 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Does he have a smallblock? But yes I have had that happen on a 340.
Re: Fuel pump push rod... [Re: JohnRR] #766306
08/05/10 10:30 PM
08/05/10 10:30 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
smallblock??? No pushrod so I'm assuming big block. Don't think the dimensions he's listed are the problem
Re: Fuel pump push rod... [Re: Bee4spd] #766307
08/05/10 11:12 PM
08/05/10 11:12 PM
Portland, Or.
Bee4spd Offline OP
Bee4spd  Offline OP
Portland, Or.
Thanks guys. Yes it is a big block. And I figured out the problem. I had to use a syphon pump to get fuel all the way to the inlet lines on the Holley. Never had to do that before, even when the car sat for a looooong period of time. Now if there were only a way to truly figure out what they put in the gas to jelly all of my rubber lines!
Re: Fuel pump push rod... [Re: Bee4spd] #766308
08/06/10 01:08 AM
08/06/10 01:08 AM
How long was it sitting? could anybody have sugared your tank
Re: Fuel pump push rod... [Re: RapidRobert] #766309
08/06/10 03:09 AM
08/06/10 03:09 AM
Portland, Or.
Bee4spd Offline OP
Bee4spd  Offline OP
Portland, Or.
At that point it hadn't sat very long at all(two days). It was also in my garage most of the time after the fill up(locking gas cap as well). One thing is that the fuel had more of the feel of alcohol(ie. quick evaporation and immediate coolness on the skin). All of the rubber lines had been replaced within the past ten years, I didn't think this would have been a problem since "oxygenated" fuels had been around awhile at that point. Still kind of weird. The good thing is that it forced me into using the good stuff(Aeroquip), which really I should have done many years ago.
ps. I think the sugar thing is a myth. The old hoses integrity were completely compromised. The outer shell was balloon like with the internal being squishy. I don't think any amount of sugar could have caused that.
Re: Fuel pump push rod... [Re: Bee4spd] #766310
08/06/10 03:50 AM
08/06/10 03:50 AM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
sounds like you filled it with e-85
Re: Fuel pump push rod... [Re: 05dakota] #766311
08/06/10 03:11 PM
08/06/10 03:11 PM
Portland, Or.
Bee4spd Offline OP
Bee4spd  Offline OP
Portland, Or.
It would be nice if it was available that close but e-85 is pretty scarce around here.
Re: Fuel pump push rod... [Re: Bee4spd] #766312
08/06/10 10:36 PM
08/06/10 10:36 PM
Actually I was being a bit facetious . yep those symptoms sure ain't from sugar. I've only seen that in the old material hoses after years of use w E10 (gasahol) after it came out here (in Nebraska) in the mid 80's iirc or old style material hoses way back on neglected vehicles in pre gasahol days that hadn't been changed in decades
