heat still blowing even when off #766152
08/05/10 03:38 PM
08/05/10 03:38 PM
Ohio
rck850 Offline OP
rck850  Offline OP
Ohio
The heat in my 74 roadrunner is still blowing down on the floor and defrost vents even when the levers are in the off, low temp position, and the blower is off. I've looked all over the box and can't find a disconnected lever or one that isn't adjusted right or in the wrong position. The car is black/black and having the heat on is not fun.
Re: heat still blowing even when off [Re: rck850] #766153
08/05/10 04:09 PM
08/05/10 04:09 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
make sure that the water valve is shutting off. If it isn't there is hot coolant circulating through the heater core.
Re: heat still blowing even when off [Re: rck850] #766154
08/05/10 04:25 PM
08/05/10 04:25 PM
Pittsburgh, PA
Slotts Offline
Slotts  Offline
Pittsburgh, PA
Is this an A/C car? It sounds like one of the vacuum actuators is not working leaving the door open.
Slotts
Re: heat still blowing even when off [Re: Slotts] #766155
08/05/10 04:33 PM
08/05/10 04:33 PM
Ohio
rck850 Offline OP
rck850  Offline OP
Ohio
I have no vacuum actuators under the dash and it is a non A/C car.
Re: heat still blowing even when off [Re: rck850] #766156
08/05/10 05:20 PM
08/05/10 05:20 PM
USA
DAK512 Offline
DAK512  Offline
USA
I would have to say that one of the doors has broken off inside of the heater box
Re: heat still blowing even when off [Re: DAK512] #766157
08/05/10 06:43 PM
08/05/10 06:43 PM
Upper Midwest
Upper Midwest
And if the water valve isn't shutting off it will blow hot air.
Re: heat still blowing even when off [Re: MoparforLife] #766158
08/06/10 02:18 AM
08/06/10 02:18 AM
Ohio
rck850 Offline OP
rck850  Offline OP
Ohio
No doors are broken off inside the box. and unless their is a water valve inside the heater core I don't have one. This car has 20000 original miles and still has the original 1974 heater hoses so nothing is missing.
Re: heat still blowing even when off [Re: rck850] #766159
08/06/10 03:03 AM
08/06/10 03:03 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
On a non-A/C car there is no heater control valve.
Hot water is always running through the heater core.
A cable operated door is what blocks the hot air from coming through the vents. It might have a cable out of adjustment, or has come loose at the control panel or heater box.
Some people install a manual heater control valve in a hose to block the hot water from ever going to the heater core.
Re: heat still blowing even when off [Re: rck850] #766160
08/06/10 06:43 PM
08/06/10 06:43 PM
Switzerland, Europe
Swiss_Robert Offline
Switzerland, Europe
So if the doors are okay and the cables are okay ...it seems to be a miracle!
If you can't stop air going through the box AND can't stop it from going through the heater core there are already TWO things odd...
After all these years having a 440 I realized that this means having an attitude... and a budget.
Re: heat still blowing even when off [Re: Swiss_Robert] #766161
08/07/10 02:06 AM
08/07/10 02:06 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I know in earlier cars there are little foam seals that rot away, so even when the door is closed, you still get air flow since the seal is gone.
I want my fair share
Re: heat still blowing even when off [Re: SomeCarGuy] #766162
08/07/10 03:39 AM
08/07/10 03:39 AM
Ohio
rck850 Offline OP
rck850  Offline OP
Ohio
Thats the thing. I've replaced seals and put new foam in the box all doors are working and intact. but when I drive enough air moves through the box from the cowl to blow into the cabin and make it extremely uncomfortable in 90* weather. Today I made two special plugs that go into the inlet and outlet that block the water and still allow me to have the heater hoses in place. After I did that I let the car warm up and went for a ride and it was fine.
Re: heat still blowing even when off [Re: rck850] #766163
08/07/10 04:09 AM
08/07/10 04:09 AM
Kentucky, USA
derekeh Offline
derekeh  Offline
Kentucky, USA
My cuda is the same way.. always some hot air coming out.
