small block waterpump
#765950
08/05/10 09:46 AM
08/05/10 09:46 AM
Posts: 1,139 West Tennessee
rbstroker
West Tennessee
I am using a Moroso drive kit on my stock early 273 pump. I did install the 28% overdrive pulley, but I really don't think that it flows enough. I'm sure that the stock belt drive will keep the engine cooler, but don't want to lose the HP. Any suggestions on electric water pumps. Just to make it interesting, my 1965 setup has the waterpump outlet on the driver's side.
This is the land of the free
because of the brave
Re: small block waterpump
[Re: rbstroker]
#765951
08/05/10 10:11 AM
08/05/10 10:11 AM
Posts: 6,150 Melbourne , Australia
LA360
I think from memory the Mezeire pump has the option of either a left or right outlet. Been a while since I have looked at on though.
Alan Jones
[Re: rbstroker]
#765954
08/05/10 11:43 AM
08/05/10 11:43 AM
Posts: 7,506 Az
Crizila
Az
Weld A disc on the back of the blades. It will definitely move more water that way. Probably cost you some HP though.
Fastest 300
[Re: Jamie340]
#765956
08/05/10 08:47 PM
08/05/10 08:47 PM
rbstroker
West Tennessee
This is a strip only car. I see that Summit and Jegs have a Proform 30-35gpm electric waterpump that may work. I really hate to buy Chinese parts though and I am not sure if the flow rate is enough anyway.
[Re: rbstroker]
#765957
08/05/10 09:00 PM
08/05/10 09:00 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I run a moroso electric pump on the street with no problems.It also can go to either side it is clockable.Plus it comes complete no plate need to buy.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: viperrt]
#765959
08/05/10 09:11 PM
08/05/10 09:11 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I am real happy with my Moroso electric pump
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
