I have an original 383 71 challenger with factory A/C. I have put in a 440 6 pak, but would like to use the factory air. Can this be done? Can it be done to look like original? Does anyone have pictures and part numbers of the parts they bought. I know you can't use the stock compressor because it hits the air cleaner base, so how does the sandan compressor mount and what else changes? I do have some lines, the drier, the stock compressor and some brackets from the original setup. Does anyone make a stock correct looking repo condenser? Thanks for the help.
