4l80e in an A body? #764999
08/04/10 02:03 AM
08/04/10 02:03 AM
Gainesville,FL
goldmember Offline OP
Gainesville,FL
Anyone installed a 4l80e in an A body? What clearance issues need to be addressed? Thanks
Re: 4l80e in an A body? [Re: goldmember] #765000
08/04/10 02:52 AM
08/04/10 02:52 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Thats the heavy duty GM trans, right?
Re: 4l80e in an A body? [Re: Kern Dog] #765001
08/04/10 02:58 AM
08/04/10 02:58 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Search for posts by dmerc. He put a 700r4 into his duster. IIRC, a 700r4 is basically a hydraulic version of the 4l80e with weaker internals.
Re: 4l80e in an A body? [Re: goldmember] #765002
08/04/10 08:53 AM
08/04/10 08:53 AM
New Mexico
dmerc Offline
dmerc  Offline
New Mexico
I cut out the supporting channel under the tunnel but after I got it all installed I don't think it really had to be removed. This channel also runs to the sides and is part of the torsion bar support so I had to fab a new trany mount that tied the torsion bar assy together and at the same time gave me more clearance for the trans oil pan. Hope this helps
Re: 4l80e in an A body? [Re: goldmember] #765003
08/04/10 09:06 AM
08/04/10 09:06 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
4l80 is a bigger trans than the 4l60(700r4). Will be tight fit.
Re: 4l80e in an A body? [Re: buildanother] #765004
08/04/10 09:33 AM
08/04/10 09:33 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I know Brian used a GM based trans on this one, but have no idea what model trans it is. And could probably find out if needed. I know the builder/shop manager and the cars owner.
But there are lots of good pictures to help along the way.
http://woodyshotrodz.com/project_68_dart.htm
Re: 4l80e in an A body? [Re: DaytonaTurbo] #765005
08/04/10 10:22 AM
08/04/10 10:22 AM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
700r4 is a hydr version of a 4L60E the 4L80E is much larger
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
