Moser or Strange or ? #761508
07/30/10 03:03 PM
07/30/10 03:03 PM
Bloomington, Illernoise
cptn60 Offline OP
cptn60  Offline OP
Gettin ready to get a Dana 60hd narrowed and new axles for it. Does anyone have a preference for axles, and the workmanship to narrow the housing? Moser and Strange are the two I initially thought of. Both equidistant from me, so....?
This space available for rent
Re: Moser or Strange or ? [Re: cptn60] #761509
07/30/10 03:09 PM
07/30/10 03:09 PM
Joplin, Missouri
Mac's Hemi 64 Offline
Joplin, Missouri
I purchase a complete 60 from Strange and was very happy with it.
Re: Moser or Strange or ? [Re: cptn60] #761510
07/30/10 03:10 PM
07/30/10 03:10 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Full race.........Strange or M.W.
multi use.........Moser.
But you are fishing for an opinion I hope , because there may not be a " correct " answer.
Re: Moser or Strange or ? [Re: cptn60] #761511
07/30/10 03:11 PM
07/30/10 03:11 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Go 9", don't waste your money on that heavy pig!!
Re: Moser or Strange or ? [Re: Challenger 1] #761512
07/30/10 03:42 PM
07/30/10 03:42 PM
NY usa
540challenger Offline
NY usa
Now you have do it. This post we be 8-9 pages of
Re: Moser or Strange or ? [Re: Mac's Hemi 64] #761513
07/30/10 03:46 PM
07/30/10 03:46 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
X2, it measured exatly what I specified. I had Moser axles in my 8 3/4 and had no issues though.
Re: Moser or Strange or ? [Re: Challenger 1] #761514
07/30/10 03:51 PM
07/30/10 03:51 PM
cptn60 Offline OP
cptn60  Offline OP
Funny you would say that; the man I bought the Dana from tried to sell me a narrowed 9 hsg with some really nice Mark Williams axles. May need to go back and buy it now....
Re: Moser or Strange or ? [Re: cptn60] #761515
07/30/10 05:26 PM
07/30/10 05:26 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
I sure would! That's the best you can get right there!
Re: Moser or Strange or ? [Re: MegaDart] #761516
07/30/10 05:45 PM
07/30/10 05:45 PM
Houston TX
GregCon Offline
GregCon  Offline
Houston TX
Yeah, I would get that Ford rear end and then shoot myself in the head.
Per Strange, a Dana 60 weighs about 15lbs more than a comparable 9". I'd much rather have the strength of a Dana and suffer an extra 15lbs right over the rear tires.
That said, Moser is nowhere near Strange in terms of righteousness. Strange is not perfect but they are a real aftermarket company, not a weenie company.
Re: Moser or Strange or ? [Re: cptn60] #761517
07/30/10 06:13 PM
07/30/10 06:13 PM
Canada
CrAzYMoPaRGuY Offline
Canada
I went with Dutchman axles
CrAzYMoPaRGuY
Re: Moser or Strange or ? [Re: GregCon] #761518
07/30/10 06:21 PM
07/30/10 06:21 PM
Lehigh Acres, Florida
rickstershemi Offline
Now that right there is some solid advice
Whatever you do, don't go with a Ford 9" with Mark Williams parts (only 99% run them) but chivy rods are cool
IMHO the 9" sounds like the logical choice....what was the asking $$$ on both....?????
Rickster
Re: Moser or Strange or ? [Re: CrAzYMoPaRGuY] #761519
07/30/10 06:27 PM
07/30/10 06:27 PM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
STRANGE all the way, i wasted my money with mosher once before and never again. i know they've done good with many people. when i ordered my axles from mosher i specified that i had a strange spool. the axles were the slopiest fittment in the splines. i ordered the strange and they fit perfect.
Re: Moser or Strange or ? [Re: Deepockets] #761520
07/30/10 06:45 PM
07/30/10 06:45 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
The Dana 60 is a little heavier than the 9"ford,but the placement of the pinion on the ring gear will free up a little more HP than the ford. Where the 9" ford pinion goes in at robs a little more HP than the Mopar rear end.Enought to make up for the added weight. The only reason my dragster has a 9" ford in it is I could not narrow the dana (has a much wider center)enought to use in my dragster.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Moser or Strange or ? [Re: cptn60] #761521
07/30/10 06:50 PM
07/30/10 06:50 PM
yarnell,az
mopacltd Offline
mopacltd  Offline
yarnell,az
I have been happy with Moser for the last 16 years.
Re: Moser or Strange or ? [Re: MRMOPAR622] #761522
07/30/10 08:31 PM
07/30/10 08:31 PM
Cincinnati, Ohio
Cincinnati, Ohio
Having to lay under the car to change gear ratios in a dana is why thier NOT a popular race rear end.
Because of the aftermarket, the ford is the best choice if someone was buying new.
AND...15 lbs is alot when it comes to racing. Also would guess that with aluiminum center sections for the 9", there would be a even greater weight savings.
Re: Moser or Strange or ? [Re: Challenger 1] #761523
07/30/10 09:15 PM
07/30/10 09:15 PM
Peru
cbarracuda Offline
cbarracuda  Offline
Peru
AND...15 lbs is alot when it comes to racing. Also would quess that with aluiminum center sections for the 9", there would be a even greater weight savings.
Adding weight over your rear wheels in a Drag Car makes you go faster until you get a balance of 50-50
Re: Moser or Strange or ? [Re: cptn60] #761524
07/30/10 10:07 PM
07/30/10 10:07 PM
Strange is what I use, I like my money a lot so I buy the best I can get so I don't have to spend it twice BTW, Mark williams Ti axles are nice and light, if you need them BTW, the Dana HD housing is heaveir than the regular 3/4 tona and passenger car housings
Re: Moser or Strange or ? [Re: Cab_Burge] #761525
07/30/10 10:12 PM
07/30/10 10:12 PM
Lebanon,IN
mr2performance Offline
Lebanon,IN
Either are good choices, let me know if you need pricing. Mike
MR2PERFORMANCE RACE CARS 765 483 9371
Re: Moser or Strange or ? [Re: mr2performance] #761526
07/31/10 02:30 AM
07/31/10 02:30 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
get a 9'' easier to work on and stronger,,,alston chassis makes by far the nicest housing,,,blows mosers away and strange,,inner tubes welded the whole 9 yds!400 and change for the housing
Re: Moser or Strange or ? [Re: fishy340] #761527
07/31/10 12:09 PM
07/31/10 12:09 PM
cptn60 Offline OP
cptn60  Offline OP
Well thanks folks for the opinions. I went back and bought the 9" paid $400 w/axles no center. The Dana was $125 complete. These MW axles are so pretty I may just buy a set from them after I narrow the housing locally. Found a shop w/ a jig and will tig weld it for 150.
