MP elektronic Distributor #760828
07/29/10 02:37 PM
07/29/10 02:37 PM
Denmark, Helsingor
AAR70 Offline OP
AAR70  Offline OP
Denmark, Helsingor
Hi,Does someone know how much total mekanical advance the MP distributor have ?
Re: MP elektronic Distributor [Re: AAR70] #760829
07/29/10 03:04 PM
07/29/10 03:04 PM
NY usa
540challenger Offline
NY usa
Hi,Do someone know total mekanic (Not vacuum) advance on the MP elektronic distributor there fit small block?
Not sure about your question.
Do you mean how to adjust the mech advance or how to tell how much is in the distributor ??
Re: MP elektronic Distributor [Re: 540challenger] #760830
07/29/10 03:23 PM
07/29/10 03:23 PM
Denmark, Helsingor
AAR70 Offline OP
AAR70  Offline OP
Denmark, Helsingor
how much is the MP distributors total mekanical advance out the box? 22 24 26 28 degree?
Re: MP elektronic Distributor [Re: AAR70] #760831
07/30/10 11:31 AM
07/30/10 11:31 AM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
hej,messed with mine bought in 97 the other day.its got 27 degrees mech advance.as a bonus i can tell you that the vacuum can can be adjusted between 6-17"inches of jadajada,it is between those nr of hg"vacuum it starts to add the extra advance.dont know if my vacuum meter is accurate but the mech advance ive checked with 3 timing lights and if i remember right they where pretty close to each other,my 25 year old BILTEMA timing light red the same as my also old back-dial snap-on. this is off off a bb mp distributor.
Re: MP elektronic Distributor [Re: AAR70] #760832
07/30/10 01:30 PM
07/30/10 01:30 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
How old is this distributor ? Newer units have an adjustable mechanical advance , old units to have to weld the slots .
