ALMOST STOCK 440 11.00 ON MOTOR?
#760252
07/28/10 05:49 PM
07/28/10 05:49 PM
Posts: 197 New York
Dustin71
New York
COULD A 30,OVER...STOCK STEEL CRANK 440 WITH GOOD H-BEAM RODS. GOOD PISTONS. 825 DR DEMON FULLY PORTED WIEND INTAKE. 906 STEEL FULLY HOME PORTED HEADS. STOCK STEEL STAMPED ROCKER ARMS. STOCK PUSH RODS. HYD CAM, HYD LIFTER. AUTOMATIC...3500 CONV...(NO TRANZ BREAK) 8 3/4 REAR 391 RATIO. 3440LB Duster. run 11.00ETs on motor and 10.00ETs on spray (225 HP Shot) ????????????
Re: ALMOST STOCK 440 11.00 ON MOTOR?
[Re: stumpy]
#760254
07/28/10 05:58 PM
07/28/10 05:58 PM
Posts: 197 New York
Dustin71
New York
Please turn off the caps. What pistons, what cam and what compression ratio?
SRP pistons.... 509 cam ..... 10:to 1
[Re: Dustin71]
#760255
07/28/10 05:58 PM
07/28/10 05:58 PM
dulcich
[Re: Dustin71]
#760257
07/28/10 06:06 PM
07/28/10 06:06 PM
Posts: 535 Ohio
racerAL
Ohio
this almost seems like a trick question..you don't mention what compression your good pistons are or the size of your hyd.cam...however, i would still have my doubts that you could get it to go 11.0's on motor with the info giving.
-1967 Plymouth Satellite #3555 446 cid on E-85 best 1/4 et 10.577 @ 127.58 best 1/8 et 6.722 @ 100.68 best 60ft. 1.419
[Re: Dustin71]
#760260
07/28/10 07:27 PM
07/28/10 07:27 PM
Posts: 10,233 Someplace you aren't
SomeCarGuy
I'm going to guess the owner is saying to you-
"Runs 11s on the motor and 10s on the bottle."
Not necessarily 11 flat and 10 flat.
I want my fair share
[Re: RobX4406]
#760264
07/28/10 09:08 PM
07/28/10 09:08 PM
Posts: 197 New York
Dustin71
New York
I see 11.00 and 10.00.
It's all fun til someone gets hurt! LOL
[Re: thehemikid]
#760269
07/29/10 08:57 AM
07/29/10 08:57 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
BTW that's hardly an almost stock motor. I wouldn't consider a ported headed/intake big carb, headers, h-beams, good pistons...509 cammed motor almost stock. Almost stock would be a stock bore 9:1 cast piston, non-ported iron head, small cam, intake and 750dp an almost stock motor.
[Re: Dustin71]
#760271
07/29/10 12:37 PM
07/29/10 12:37 PM
Posts: 199 douglasville,ga
ramrod
douglasville,ga
I'll say 11 flat is a reach on motor, but possible. I knew a local bracket guy who ran a very-near stock Magnum spec 440 in a Duster to very consistent 11 teens. He claimed to run a "small MP solid cam" and no other mods aside from induction and headers. Keep in mind that this was a well thought out bracket car, so the converter and rear gear were part of the combination and the chassis didn't give up any E.T.
A 3440 lb Duster is a heavy Duster IMO, especially if it is a 1st gen. My '71 Duster bracket car weighs 2830lb with an 8 pt cage. It's all steel except for a fiberglass hood and still has all the original window glass.
"That Plymouth had a Hemi with a Torqueflite."
-Driver
