Re: How much H.P. increase with Shaker
[Re: ragtop]
#760175
07/28/10 07:59 PM
07/28/10 07:59 PM
Posts: 13,031 Benton, IL.
DaveRS23
Master of nothing...
Benton, IL.
It's been my experience that the fresh air systems don't make any extra horsepower. But they allow the engine to make it's best horsepower more often. For an example, my Cuda will run the same numbers the first pass of the day with and without the Shaker. BUT, it will loose about a .1 if I make another run rather soon without fresh air. And will loose about another .1 if I make yet another run fairly soon without fresh air. It's the temp of the air that the carb gets that is the key to fresh air systems. Until the underhood temps exceed the outside air, there is not much advantage to fresh air systems. But as the underhood temps climb and the difference between that air and the outside air widens, so does the advantage of the fresh air system. The biggest difference I have seen with my car with and without outside air has been about .25 in the 1/8. Well worth the effort since I often need to make back to back runs. On a similar note, my electric cut-outs pick the car up about the same. Except the cut-outs increase the performance that much. Not just maintain what it is already doing.
Master, again and still
[Re: ragtop]
#760179
07/29/10 02:18 PM
07/29/10 02:18 PM
Posts: 72 Pgh, PA
Nino
Pgh, PA
I've never had one, so I can't say from experience, but I did remember running across this 1970 Rapid Transit Authority ad on the Hamtramck website that touts that the shaker option boosts quarter mile time: "Aside from the fact that it looks tough and girls dig it, it's good for .15 to .20 of a second in the quarter." I can't say if it's true or not, but it's still a cool ad...
1970 Dodge Coronet
1968 Barracuda FB
1970 Duster
1974 Dart
1977 Dodge Custom Van
[Re: Nino]
#760180
07/29/10 03:02 PM
07/29/10 03:02 PM
In 1976 my pal Wayne Hyland and me raced his 71 Cuda 340 shaker billboard orange 4 speed at the local dragstrip all summer long--it ran a tenth better in the 1/8 with the shaker on his front porch--we came home one day and the garbage man had taken the shaker with the other stuff his mom left out for them Oh well........ that was one heck of a car for a couple of thousand $$. I can't quite remember how many clutch sets it took to do that.
[Re: ]
#760181
07/29/10 08:39 PM
07/29/10 08:39 PM
Posts: 4,872 connecticut
pnypwr
connecticut
I dynod my cuda with it open and closed, didnt make a difference on peak numbers, it did however move the curve a little bit...
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd 74 gremlin x 360 65 mustang 347 70 coronet R/T 440 03 Mach 1
