chevy rods in small blk Mopar
#759866
07/27/10 11:50 PM
07/27/10 11:50 PM
Posts: 1,031 Raleigh N.C
hemiparts
"Missile Pilot"
"Missile Pilot"
Raleigh N.C
Ok please hear me out before the stoning begins.. I bought a set of pistons to replace mine that were damaged in my All-Out engine explosion.. Problem turns out that upon arrival the JE pistons have a .927 wrist pin ( std sml blk chv) well after an exhausting search i found very few manufact. that make a mopar rod with that smll pin. A well respected Mopar drag racer and engine builder recommened that I take a 6.125 sml blk chevy rod and have my crank ( that i am going to have to have turned down anyway) turned down to a chevy journal size and then go to "Wal-Mart" and take you pick of rods. Any feelings ??? recomendations ??
Re: chevy rods in small blk Mopar
[Re: hemiparts]
#759869
07/28/10 06:45 AM
07/28/10 06:45 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Its done alot of times... 2 of my engines have chevy rods, both use the 6.125 rod... on my W-9 engine I surface ground the big end .013 on each rod(I believe that was the amount)... if its not a big power or high reving engine just have the crank widened the proper amount... talk to the crank grinder to see what they say
[Re: TheOtherDodge]
#759871
07/28/10 09:10 AM
07/28/10 09:10 AM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
yeap I am running a 6.125 chevy rod in my 416 strocker
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: Cab_Burge]
#759876
07/28/10 12:10 PM
07/28/10 12:10 PM
Posts: 2,864 IN
Irun5snd8th
IN
Sidebar question: Do you have to do grind the rods if you use the callies crank that is the Chevy journal size?
AFCO, Rons Fuel Injection sponsored Dodge Challenger
Mention Street Lethal Motorsports
[Re: Irun5snd8th]
#759877
07/28/10 12:19 PM
07/28/10 12:19 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
No, if the crank is cut for 2.100" rods then it will already be a wider cut.
THE RODS YOU GUYS ARE SPEAKING OF ARE NOT CHEVY RODS UNLESS YOU BUY THEM FROM GM.
I was pretty sure Eagle made several rods with a chrysler sized big end and a .927 little end. You could always bush your chrysler sized rod down to .927 if you already have rods. Steel rods with a 2.100 big end allow more clearance in stroker applications and are lighter. But you cut premium hardened material off the crank to switch over to the smaller journal. Unlike cranks that are made for that journal. I have a set of C&A alluminum rods for chrysler with .927 pins. Common rod.
Leon
[Re: Oyvind Mopar]
#759880
07/28/10 10:19 PM
07/28/10 10:19 PM
Posts: 12,478 Kalispell Mt.
HotRodDave
Kalispell Mt.
Why not just stick a bushing in your rod and be done with it?
[Re: Oyvind Mopar]
#759881
07/28/10 11:02 PM
07/28/10 11:02 PM
Posts: 622 NC
chris3
NC
Let me run some statistics on this engine build and what we are up against. The pistons were special ordered, made by JE, for a mopar 340 and the "chevy" size pin. The individual who ordered the pistons had the same problem, no rods with that pin and he did not take the pistons. I bought the pistons at a deal. Thirty years ago we would swap rods and do all kinds of things.
Issue number one. Don't want to offend anyone here because a lot of good information is available from the members of MOPARTS and all help given to us is appreciated. I have looked at catalogs and made untold number of phone calls to rod manufacturers, Eagle,Lunati,Crower,Carrella, G&R, etc. with no luck with a mopar dimension rod with the small chevy pin.
Issue number two. To the machine shop to have the little ends of the rods re-bushed. No bushing material in any catalogue that has the correct outside diameter to fit the Chrysler end and an inside diameter that can even be honed to the correct "chevy" size. Only suggestion was to buy brass and take it to a tool and die shop and pay the cost to have bushings custom made and installed.
We talked with a famous old time MOPAR builder and decided to look at a "chevy" rod. I have read all of the suggestion and appreciate all of the suggestions. Here are some numbers. Rods are available from every rod manufacturer with the small "chevy" pin and the standard "chevy" big end. Now to the crankshaft. A standard Mopar 340 crankshaft measures 1.862 inside to inside crank journal. Mopar Performance steel,shot peened and bushed rods measure 0.914, two rods plus 0.035 rod clearance equals 1.862. Two "chevy" large and small journal rods, 6.125 long measure 0.945 each plus the 0.035 rod clearance equals 1.926 that is 0.064 too wide for the Mopar crank journal.
As I see this situation we need to get the "chevy" rods 6.125 long with the 2.10 big end diameter and have the sides of the rods ground 0.064 total which means 0.016 off of each side of the two rods. Other alternative is to grind the 0.032 from each face of the crankshaft journal.
While we are talking connection rods and combos, there is a speed parts shop in Hunterville, NC which buys left overs from all of the NASCAR shops. You can get some real deals here if you know what you want. Went there looking for rods. 90% of the engine parts here are made for Ford and Chevy, remaining are pontiac, oldsmobile and buick. There were racks of connecting rods bundle together in groups of 8 and tagged. Most of there rods are 5.50 and 6.125 with crankshaft ends measuring 1.50, 1.55, 1.75, yes you guessed it these are Honda and Toyota crankshaft dimensions.
[Re: TheOtherDodge]
#759883
08/04/10 11:34 AM
08/04/10 11:34 AM
Leon441
Lynchburg, VA
I made a few calls....You're welcome
With the airospace industry slowing down lately. The bushing they don't sell a lot of are hard to justify stocking. Not saying you can't get a steel rod Mopar big end and .927 little end but it may be a challenge. Basically they have taken that option out on steel rods. You can readily do it with alluminum but then you get into a rod bearing problem as Akerly and Childs is the only place I know selling an HD bearing for SBM.
All this said turn the crank down to 2.100" and widen the journal to fit the GM bearing size. Don't like to but its been done successfully for years.
Leon
[Re: Leon441]
#759885
08/04/10 04:20 PM
08/04/10 04:20 PM
Posts: 8,547 State College, PA
RyanJ
moparts member
moparts member
State College, PA
Leon
I hav'nt read this whole post but just quickly....
I have had custom OD/ID rod bushings made by Crower/Carrillo & Precision products all within last couple years... no big deal to find a custom bushing these days. Usually about $15-$20 a pop. Precision will usually make them in 1-2 days & they are who I would recommend dealing with.
Almost every engine I build has a SB GM rod of some sort in it.... if Crank is Chrysler Journal we just grind it to 2.10 or 2.0" GM journal & you just sweep them to GM width, no biggie, it's done all the time. Alot of aftermarket SB Mopar cranks today are now avail with 2.10" or 2.0" SB GM journal right off shelf....
