Re: Brake Hose Question
[Re: Gary67]
#75863
06/19/08 09:33 AM
06/19/08 09:33 AM
Posts: 27,728 places
79powerwagon
places
You might try thicker copper washers, have heard some of the ones the give to use you aren't thick enough...
This is very true. You need the correct washers.
[Re: CUDAJAS]
#75865
06/19/08 11:50 AM
06/19/08 11:50 AM
RapidRobert
MP still has the ones with the circular ribs on them as oppose to th flat surface of the ones that come with the calipers. I cant find the pn but somene will know it. & some of those in with the caliper boxes arent thick enough to be above the recess where the hose mounts.
[Re: RapidRobert]
#75866
07/17/08 04:38 PM
07/17/08 04:38 PM
Posts: 2,072 Cambridge, Ontario, Canada
CUDAJAS
Thanks guys,
Anyone have that part number???
[Re: CUDAJAS]
#75867
07/17/08 07:09 PM
07/17/08 07:09 PM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
If you have the old ones clean them and reuse them.Ive found most new wahers are trash.I reuse the old ones even at work and have never had a leak.Rocky
Chrysler Firepower
