motor runs ruff at idle the hotter the motor gets the worse it runs i hook a tach to it and cant get even fire it jumps almost three hundred rpms at idle up and down every thing has been replaced except votage regulater , spark control unit is new and checked , new distributor ignition timing my be off a degree or two but dosent seem to make a diference , timeing chain my have 15000 miles on it so im thinking coil ive had a short in the fuse box that sent twele volts to the coil and the rest of the system and hasnt been right sence any sugestions would help.
the coil dose have six volts coming out both terminals dosent seem to be grounded but if i run a strait ground to the fire wall it just kills the motor
