Short block suggestions BB
#756083
07/23/10 07:37 PM
07/23/10 07:37 PM
Posts: 83 Southern IL.
jafr
Southern IL.
I would like some input from you guys on building a new short block. what size, whose rotating assembly, what machine work, camshaft etc. Currently I am running a 470ci with 12.7 compresion, indy sr heads with some mild port work,ultra-dyne roller [Email]278@50[/Email] and .680 lift both on the intake and exhaust, the intake is a victor intake with a flying toilet on top, headers are 2 1/8" with 4" collectors poweglide trans with 1.80 low gear. Currently the car runs 5.90 to 5.95 @ 117 to 120mph depending on the weather. The car is a 69 dart with a full tube chassis strut front with 4-link rear, the cars weight is approx. 2780lbs with me in it. I would like to stay with a low deck. I was looking at Muscle motors 511 rotating assembly. Thoughts good,bad? Thanks ahead of time for the suggestions. Joe
Re: Short block suggestions BB
[Re: jafr]
#756089
07/24/10 09:43 PM
07/24/10 09:43 PM
Posts: 43,285 Bend,OR USA
Cab_Burge
I originally built a pump gas 511 CI low deck stroker for my street car, ported, polished, big valves 906 iron heads with standard size 440 ports. solid roller cam with a six pak, 9.25 to 1 comp. ratio, that motor made 612 HP at 5600 RPM and 644 ft. lbs at 4500 RPM on CA pump gas I later hopped that motor up by increasing the stroke to 4.300(from 4.250) and changed the heads to a set of CNC ported Eddy RPM with 440 size ports,(10.29 to 1 Comp ratio, still a pump gas motor ) that woke the motor up to where it made 718 HP at 5800 RPM and 740+ ft. lbs at 4700 RPM on pump gas. Are your SR max wedge size or 440 size? Are you running gas, alcholol or E 85? I have built many different combinations of BB for different application, I have a 526 C.I. 440 block that has a set of M.W. size SR on it that is a bracket race motor run on race gasoline, it is right at 13.0 to comp. ratio. It made 775 HP on a DTS engine dyno in Klamath Falls (4300 FT above sea level)last summer with a single 1050 CFM dominator and and 805 HP using Indy tunnel ram with two 1050 Dominators on it. Earlier that year I built and dynoed a 470 C.I. (3.91 stroke, 4.80 bore , 440 bock) bracket motor with B1-BS heads that had been CNC ported to M.W. by MCH, that motor had a custom built tunnel ram with a set of 750 Holley D.P. set up by JET racing, it made 721 HP at 7000 RPM, we quit pulling the motor at that RPM per the customers desires, it had not reach peak HP yet at that RPM Bottom line I would build the motor as big as I could and make sure the heads are max out also, big motors need big air, big cams,big exhaust and so on I like 4.300 or a 4.375 stroke in a 400 block with a 6.700 long H beam rod with chevy rod journal sizes and ,990 wrist pins, small as possible combustion chamber sizes and as much compression as you can run on the fuel you want to race with
[Re: jafr]
#756093
07/25/10 12:14 PM
07/25/10 12:14 PM
Posts: 16,930 NC
440Jim
NC
Here is an idea:
Indy MAXX low deck aluminum block, 4.44-4.50" bore. Callies 4.250" stroke crankshaft 6.535" long rods (BB Chevy +.400", 2.200", 0.990") For alcohol, get the CR up to 14 or so. I like the Fyling Toilet Injection
Max Wedge port the heads, intake to match. Should be pretty stout! Check with Jeff at Modern Cylinder Head for port work.
[Re: 440Jim]
#756094
07/25/10 01:14 PM
07/25/10 01:14 PM
jafr
Southern IL.
Mr.Cab, you have some pretty good info. Your sr headed motor seems to make some pretty good steam.
Jim I wish I could afford a indy or world block but the price is just out of my budget currently. The reasons I would like to stay with a low deck are, 1)my headers are custom made and sit very close to the frame an floor, 2) I already have 2 400 blocks. 3)I have 2 intakes already drilled for injection and it would save a little $. 4) from what I have read the 400 is a little stronger in the main area? What combination are you running that motor is plenty stout to move a heavy car that quick. Looks like Jeff at Modern Cylinder Head has a good rep!
[Re: jafr]
#756097
07/25/10 05:18 PM
07/25/10 05:18 PM
Posts: 16,930 NC
440Jim
NC
I am near sea level elevation, so that helps. Here is the combo:
4.250" Stroke Callies Crankshaft, 4.375" bore, 511 CID BEST Machine aluminum main caps, 400 block align bored to 440 main size SCAT H-beam rods, ARP 2000 bolts, 6.535" long, 2.200/0.990 Milodon windage tray with custom crank scraper welded on
Indy 440-1 heads with about the same flow as my Stage VIs milled to 68cc for 13.5 CR with flat top pistons, older Muscle Motors porting: _Lift Intake Exhaust 0.700 350.3 264.8 0.800 368.5 280.5
Solid lifter cam (flat tappet) with EDM oil hole lifters: Comp Cams MM305S-10: 305º/320º@.020", 279º/287º@.050", 197º/200º@.200", 110 LSA 0.690"/.670" lift with 1.6 Indy rockers (.650/.630 published at 1.5) Isky 9005 valve springs: 150 seat (1.95"), 440 open Indy 400-3 intake, port matched to Indy gasket Ron's Flying Toilet injection, 4.1" (1800 CFM ) with E85 fuel Custom built headers, 2-1/8” tubes 32" long, 4” collector
727 Torqueflite transmission 4.30 gears in a Dana 60 5400 converter 31.25 x 12.2 W Phoenix slicks (actually 31.8" tall)
