Replacing steering box #751112
07/18/10 10:39 AM
07/18/10 10:39 AM
Essex, Ont., Canada
Fishmarket Offline OP
Essex, Ont., Canada
I'm swapping out my tired power steering box for a new steer and gear unit in my 1971 RR. It is a 383 ac car with manifolds and power brakes. What's the easiest way to make the swap? Manifolds off? Can I manipulate it out the bottom?
Thanks!
1972 Plymouth Cuda 340 4 speed 1971 Plymouth Road Runner 383 Auto 1970 Plymouth Duster /6 Auto
Re: Replacing steering box [Re: Fishmarket] #751113
07/19/10 01:21 AM
07/19/10 01:21 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Pulling the left manifold will help. Remove the starter too. You may need to lift the motor by removing the through bolt on the left side and raising it up a few inches. V8 cars are always a pisser. The slant six cars are a breeze though!
Re: Replacing steering box [Re: Fishmarket] #751114
07/19/10 03:33 PM
07/19/10 03:33 PM
Detroit
HogRidinFool Offline
Detroit
Just did mine on a 70 Charger. I pulled the mainifold, battery & tray, tie rod end and dropped the steering column. It's good to have a helper but you can do it by yourself. It'll take you some time but it's not rocket science. ( I can say that now becuase I alsked the same question you did and got great advice from the folks here )
Re: Replacing steering box [Re: Fishmarket] #751115
07/19/10 05:25 PM
07/19/10 05:25 PM
Easton, Kansas
Moparmedic440 Offline
Easton, Kansas
Just replaced he manual gear box in my 72 RR with a Flaming River box , just took off the drivers wheel, knocked off the pitman arm and outer tierod end so it would swing back and out of the way pulled the steering colum back a few inches and removed the 3 bolts and it was pretty easy to bring it out the bottom. No need to take off your exhaust manifolds.
Re: Replacing steering box [Re: Moparmedic440] #751116
07/19/10 07:16 PM
07/19/10 07:16 PM
NJ
440challenger Offline
NJ
can you remove it from an ebody 440 with headers without unbolting the header/lifting the motor?
