Intake manifold 383 or 440 #750659
07/17/10 07:41 PM
07/17/10 07:41 PM
NC
rc68rr Offline OP
rc68rr  Offline OP
NC
We have a edlebrock intake with 3 2bbl carbs was wondering if it's the same for a 383 & 440 ? Thanks to all
Re: Intake manifold 383 or 440 [Re: rc68rr] #750660
07/17/10 07:43 PM
07/17/10 07:43 PM
Houston TX
GregCon Offline
GregCon  Offline
Houston TX
nope
Re: Intake manifold 383 or 440 [Re: rc68rr] #750661
07/17/10 08:28 PM
07/17/10 08:28 PM
own private Idaho
N
ngpSatellite Offline
N
own private Idaho
isnt a 440 intake 1 inch wider then a 383 or 400 intake????
Re: Intake manifold 383 or 440 [Re: GregCon] #750662
07/17/10 08:30 PM
07/17/10 08:30 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
A 383 is a B Block whereas a 440 is a RB block RB meaning raised block. There is some space pl;ates that "might" let you put a b block intake on an rb engine there nothing you can do about an RB intake on a B block.
Re: Intake manifold 383 or 440 [Re: ngpSatellite] #750663
07/18/10 01:15 AM
07/18/10 01:15 AM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
.750 inch wider.
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: Intake manifold 383 or 440 [Re: Cudajon] #750664
07/18/10 07:47 AM
07/18/10 07:47 AM
Houston TX
GregCon Offline
GregCon  Offline
Houston TX
"there nothing you can do about an RB intake on a B block."
You could always use 10 or 15 extra head gaskets per side you raise the heads to the proper height! Perfectly acceptable in places where intakes are hard to come by, like Afghanistan.
Re: Intake manifold 383 or 440 [Re: GregCon] #750665
07/18/10 08:03 AM
07/18/10 08:03 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Or you can bolt the rb intake right to the 383 when you have certain stage 6 cyl heads.
Re: Intake manifold 383 or 440 [Re: GregCon] #750666
07/18/10 09:10 AM
07/18/10 09:10 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You could do something goofy like that if you were trying to put a B intake on an RB , but not the other way around .
Re: Intake manifold 383 or 440 [Re: rc68rr] #750667
07/18/10 09:52 AM
07/18/10 09:52 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
A 440 intake will not fit a 383. a 383 intake will fit a 440 with P5249189 spacers think they measure about .800 some have made them.
Re: Intake manifold 383 or 440 [Re: JohnRR] #750668
07/18/10 10:30 AM
07/18/10 10:30 AM
Houston TX
GregCon Offline
GregCon  Offline
Houston TX
No, I was correct in my sage advice. You could indeed put an RB intake on a B by using the method I described. One time, in the future, I was trapped on an island with a bunch of criminals and I had to get an old engine running in order to get off the island. The engine was a 383 but the intake had been stolen years before and all I could find was a 440 Holley Dominator intake. By using a stack of old gaskets, I was able to use the intake and escaped just as the bad guys were shooting at me. It was a hell of a deal.
Re: Intake manifold 383 or 440 [Re: GregCon] #750669
07/18/10 11:50 AM
07/18/10 11:50 AM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
Maybe on a boat? But I doupt it would have worked on a car they dont float very well.
Re: Intake manifold 383 or 440 [Re: GregCon] #750670
07/18/10 03:04 PM
07/18/10 03:04 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Where's the crack smoking smiley when you need it ?
Re: Intake manifold 383 or 440 [Re: JohnRR] #750671
07/18/10 05:19 PM
07/18/10 05:19 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
Re: Intake manifold 383 or 440 [Re: Cudajon] #750672
07/18/10 06:58 PM
07/18/10 06:58 PM
Houston TX
GregCon Offline
GregCon  Offline
Houston TX
Hey, it's not my fault if you aren't up to speed on your Ray Liotta movies.
Re: Intake manifold 383 or 440 [Re: GregCon] #750673
07/25/10 03:59 PM
07/25/10 03:59 PM
Dallas, Wisconsin
BurntOrange Offline
BurntOrange  Offline
Dallas, Wisconsin
I saw that episode.
Re: Intake manifold 383 or 440 [Re: HYPER8oSoNic] #750674
07/26/10 11:36 PM
07/26/10 11:36 PM
NC
rc68rr Offline OP
rc68rr  Offline OP
NC
Thanks I think I will sell it but want to make sure what it fits. Thanks again.
Re: Intake manifold 383 or 440 [Re: Cudajon] #750675
07/27/10 05:53 AM
07/27/10 05:53 AM
eganville ont
440beep Offline
440beep  Offline
eganville ont
A 383 is a B Block whereas a 440 is a RB block RB meaning raised block. There is some space pl;ates that "might" let you put a b block intake on an rb engine there nothing you can do about an RB intake on a B block. [/quote
1959 383 is a raised block
The first 383 was introduced in 1959, but as the raised block. The dimensions on this engine were a bore of 4.030 and a stroke of 3.750 inches
Plymouth's gonna getcha! There are 3 things that will live forever, cockroaches, Keith Richards, & slant 6 Dusters 71 gtx 440 4speed air grabber blue on blue with white vinyl roof
Re: Intake manifold 383 or 440 [Re: 440beep] #750676
07/27/10 08:05 AM
07/27/10 08:05 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Dang. You beat me to the 440 intake on the 59 383 punch.
Re: Intake manifold 383 or 440 [Re: Fury Fan] #750677
07/27/10 10:45 AM
07/27/10 10:45 AM
eganville ont
440beep Offline
440beep  Offline
eganville ont
Re: Intake manifold 383 or 440 [Re: rc68rr] #750678
07/27/10 01:45 PM
07/27/10 01:45 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Eddie did build 383 six packs. What is the part number?
Does it have a Chrysler number on it? Might be worth more to the resto clone guys.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
