Is 210-220 too hot for 440 Big Block
#749216
07/15/10 10:49 PM
07/15/10 10:49 PM
Posts: 137 Kenosha, WI wi/il border
BobN
my redone 440 gets up to cruisng around 200 and creeps into 210 whille in traffic. scared I will over heat but never has or hasnt puke up. some people say should be 190 ! others tell me dont stress it -Big blocks run hot. some goes up to 220 , not to worry so much. 230-240 is hot but not 210 , What is serious and what will happen if I over heat???! new aluminum 4 cylnders engines blow head gastket and possible damage. What about mt 440??????????????? i spend more time looking at my temp gauge than enjoying my ride...
Re: Is 210-220 too hot for 440 Big Block
[Re: BobN]
#749219
07/15/10 11:28 PM
07/15/10 11:28 PM
RapidRobert
More info on what you have, fan/shroud/location of fan in the shroud/rad/wp
[Re: RapidRobert]
#749221
07/15/10 11:37 PM
07/15/10 11:37 PM
Posts: 2,091 Delray beach, Florida
Performance Only
i'd prefer to see 195 degrees or less. the late model engines handle the higher temps much better with their fuel injection, etc. carbureted engines don't tolerate the heat nearly as good.
machine shop owner and engine builder
[Re: 68LAR]
#749226
07/16/10 09:20 AM
07/16/10 09:20 AM
Challenger 1
Cincinnati, Ohio
This doesn't make it right.... Big blocks DO NOT run hot, unless your cooling system isn't up to par. Example, my engine doesn't go much above 175* even in traffic and 90+ degree days. I run a 160* thermostat, Aliminum 2 core rad.,clutch fan with a shroud, stock water pump. Nothing exotic.
I agree, I have a sb and a bb both with stock cooling systems and they run 180 even at idle. At 210 something is lacking.
[Re: RichV]
#749230
07/16/10 12:48 PM
07/16/10 12:48 PM
808CUDA
Do you have an OE waterpump housing? Some of the aftermarket housings have restricted flow passages.
Hmmm... I am running into a similar dilemma. (sorry if I am hijacking thread) Running a '69 440+6 which I recently installed a set of Eddy heads and .557 MP solid cam. For cooling I have a 440 source waterpump and housing, recored original 3 core radiator and an MP viscous clutch with shroud. I do notice my temp climbs pretty quickly to 190 deg and starts to climb to 220 if I sit in traffic or get on it a bit. A friend suggests running dual 10" electric fans because he said he had the same issue when he hot cammed his 440. I'm also wondering if the location of the temp sensor means anything. It is not located in the same location in the stock housing, rather on a tapped port on the left sode of the engine.
Any thoughts?
