Re: price for re-splining axles
[Re: SNK-EYZ]
#747900
07/14/10 07:17 AM
07/14/10 07:17 AM
Posts: 20,333 Park Forest, IL
slantzilla
Park Forest, IL
I had a pair done about 10 years ago by Moser. It was $85 then. On a street car you'll be fine. Hook it up good and you'll twist them eventually.
[Re: slantzilla]
#747902
07/14/10 04:06 PM
07/14/10 04:06 PM
Posts: 10,958 Oakdale CT
gdonovan
Oakdale CT
Got mine done at Moser, hammered them for years with a hot small block & stick without problem.
Be warned that most aftermarket axles REQUIRE green bearings and removal of the block in the shur-grip.
Don't waste time trying to get a company called Dutchman to cut down your axles, I went that route recently and it turned into a fiasco.
Moser has to clean up the mess, should have contacted them again.
[Re: president61]
#747903
07/14/10 04:18 PM
07/14/10 04:18 PM
RapidRobert
C body ones most likely good but hook your tape over the flange and measure out toward the splines & if you have 28" or more before it starts to neck down you are in good shape
