Funny boxes at firewall... #744804
07/10/10 04:13 PM
07/10/10 04:13 PM
Switzerland, Europe
Swiss_Robert Offline OP
Switzerland, Europe
Yes, I could find out myself... but I'm sure you'd love to help me even with an easy thing.
Oh: It's an 1970 Challenger with 440 in.
After all these years having a 440 I realized that this means having an attitude... and a budget.
Re: Funny boxes at firewall... [Re: Swiss_Robert] #744805
07/10/10 04:18 PM
07/10/10 04:18 PM
Truckville, the capital of NY
85_Ram_4speed Offline
The blue box is the ignition module, the black box is the voltage regulator.
Is the stuff on the firewall coming from the ignition box above it? if so its getting real hot and melting the potting out the back.
Otherwise its probably seam sealer or rustproof stuff that was on there and maybe weeping out with the heat.
Outcast Dodge guy.
Re: Funny boxes at firewall... [Re: 85_Ram_4speed] #744806
07/10/10 06:56 PM
07/10/10 06:56 PM
IMGTX Offline
IMGTX  Offline
What he said about the Blue being ignition and the black voltage regulator.
The goo running down the firewall is from the sealer they put on the circuits. If you flip the box over it is open on the back and they fill it with a rubber like stuff. It will eventually start to melt and leak out from age. It does not mean the part will not work but it will continue to leak worse and worse until you replace it or it dies on it's own. I have used them oozing for years but I would replace it to keep the firewall clean.
Re: Funny boxes at firewall... [Re: IMGTX] #744807
07/10/10 07:06 PM
07/10/10 07:06 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
That 'goo' will run out even if the part is not hooked up, just takes enough heat. If you ever have an extra one laying around your garage, try to store it face down, otherwise you may not get it off the shelf you set it on!
This may not be as much an issue where you live though (it gets HOT here in TX)......
John
Re: Funny boxes at firewall... [Re: SattyNoCar] #744808
07/11/10 01:01 PM
07/11/10 01:01 PM
Switzerland, Europe
Switzerland, Europe
Oh boy - another sick part
It comes from the ignition unit - that stuff is soft and near liquid. As raisin like said. Although there are just about 80 deg F in the Garage.
No way to save it? Is it all around the important stuff? Electronic poured in?
Or is it recommendable to replace it anyway? Against a stock part? (I never had to deal with such an ignition...).
Is it a part that runs or runs not - or is it a part that I should search and read all posts about???
Re: Funny boxes at firewall... [Re: Swiss_Robert] #744809
07/11/10 01:28 PM
07/11/10 01:28 PM
Switzerland, Europe
Switzerland, Europe
Re: Funny boxes at firewall... [Re: Swiss_Robert] #744810
07/11/10 01:39 PM
07/11/10 01:39 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
You have a generic electronic ignition conversion on your Challenger.(probably from Summit) Challengers didn't come with electronic ignition in 1970. That module was used on Challengers from 72-74. They didn't mount dirrectly to the firewall either. They mounded to a bracket that spaced the module away from the firewall to eliminate some heat.
This is a common upgrade. If you are going for a stock look, you'll have to go back to the points style ignition. If you just want to replace the module, get the "chrome" one. The qualilty of the "orange" boxes has gone down hill in the last few years. You can also get one from a parts store...it's up to you.
Re: Funny boxes at firewall... [Re: Swiss_Robert] #744811
07/11/10 01:52 PM
07/11/10 01:52 PM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
For a resto, yes. FBO makes a better ECU. Mopar orange boxe quality has been questioned lately. If its a stock or mild build, an aftermarket generic ECU would probably do.
Re: Funny boxes at firewall... [Re: pishta] #744812
07/12/10 07:03 PM
07/12/10 07:03 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
Chrome box mounted on bracket from Rocket Resto. Hides it a bit Mounts to back of valley pan. Has slots to alow the heat to get out. Hides it a bit to keep under hood looking more stock. Works great.
