SB GUYS RUNNING UNDER INTAKE BAFFLES?? #741980
07/06/10 04:10 PM
07/06/10 04:10 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline OP
Just wondering if any of you guys use a baffle that sits in the lifter galley to keep oil off the intake?? I have one but think the lifters will hit it. I PMed a SB engine builder and he said not to use it but just thought I would ask what others are doing??
Re: SB GUYS RUNNING UNDER INTAKE BAFFLES?? [Re: MIKES_DUSTER] #741981
07/06/10 05:29 PM
07/06/10 05:29 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
I havent used one in years
Re: SB GUYS RUNNING UNDER INTAKE BAFFLES?? [Re: DavidDean] #741982
07/06/10 05:31 PM
07/06/10 05:31 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
i use mine on a solid cam, 520/540 lift.
Re: SB GUYS RUNNING UNDER INTAKE BAFFLES?? [Re: MIKES_DUSTER] #741983
07/06/10 05:34 PM
07/06/10 05:34 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
I've used them in the past and the lifters didn't hit. They won't fit with an Air Gap intake, but then again they aren't needed with one either. If it would fit I would still use it so that in the event of a valve train failure the lifters couldn't come out causing a massive oil pressure loss.
Re: SB GUYS RUNNING UNDER INTAKE BAFFLES?? [Re: MIKES_DUSTER] #741984
07/06/10 05:51 PM
07/06/10 05:51 PM
Illinois
colt340 Offline
colt340  Offline
Illinois
I use with a 600" solid cam.
Re: SB GUYS RUNNING UNDER INTAKE BAFFLES?? [Re: colt340] #741985
07/06/10 07:27 PM
07/06/10 07:27 PM
Anyone have any pics of them in the block??
Re: SB GUYS RUNNING UNDER INTAKE BAFFLES?? [Re: MIKES_DUSTER] #741986
07/06/10 10:05 PM
07/06/10 10:05 PM
Under My Car
Mopar_Country Offline
Under My Car
I run one in mine, no problems, street car though with .474 lift.
Re: SB GUYS RUNNING UNDER INTAKE BAFFLES?? [Re: Mopar_Country] #741987
07/06/10 10:14 PM
07/06/10 10:14 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I have one I made and when I pulled my intake off after running it there was no oil on the bottom of the intake to speak of.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: SB GUYS RUNNING UNDER INTAKE BAFFLES?? [Re: dusturbd340W5] #741988
07/07/10 04:47 AM
07/07/10 04:47 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
I run one under my t-ram
It does 2 things for me :
1 - keeps the oil off the bottom and keeps the intake cooler
2 - in the event of a valvetrain failure it will keep the lifters in the bores so I dont have a loss in oil pressure.
It wont work with roller lifters.
