Motor plate 1/4" or 3/8" #741151
07/05/10 09:33 PM
07/05/10 09:33 PM
Pennsylvania, USA
Big_Fish Offline OP
Big_Fish  Offline OP
Pennsylvania, USA
I've been fighting a slow leak from my water pump. I pulled it about 3 times in the past to reseal it. Today I pulled the plate, cleaned everything up and noticed the plate has a slight bow. I measured it and it's 1/4" thick aluminum. I'm thinking of getting another plate made that's 3/8" thick 6061 T6. Just wondering if I should buy a new plate and if it's worth the expense in the hope of fixing this stupid seep. S&W is right around the corner so I could probably have them use my old one as a template and make it on the water jet. Is 3/8" thick more typical than a 1/4" plate?
Re: Motor plate 1/4" or 3/8" [Re: Big_Fish] #741152
07/05/10 09:44 PM
07/05/10 09:44 PM
Under My Car
Mopar_Country Offline
Under My Car
A friend of mine has 3/8" in his dart and doesn't seem to have any issues. I would think 1/4" to be a little lite.
Re: Motor plate 1/4" or 3/8" [Re: Mopar_Country] #741153
07/05/10 09:46 PM
07/05/10 09:46 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I am running a 1/4 plate on my SB no problems so far
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Motor plate 1/4" or 3/8" [Re: dusturbd340W5] #741154
07/05/10 10:04 PM
07/05/10 10:04 PM
Pennsylvania, USA
Big_Fish Offline OP
Big_Fish  Offline OP
Pennsylvania, USA
Guess I should have mentioned it's on a 440 as well. This sucks. Spent the day working on this in 100deg heat and didn't get it back together as I had hoped.
Post deleted by Defbob [Re: dusturbd340W5] #741155
07/05/10 10:05 PM
07/05/10 10:05 PM
Re: Motor plate 1/4" or 3/8" #741156
07/05/10 10:18 PM
07/05/10 10:18 PM
Pennsylvania, USA
Big_Fish Offline OP
Big_Fish  Offline OP
Pennsylvania, USA
Cool, thanks for the feedback. Now to see if S&W can do a quick turnaround since they're a few miles away.
Re: Motor plate 1/4" or 3/8" [Re: Big_Fish] #741157
07/05/10 10:42 PM
07/05/10 10:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Are you using gaskets... they tend to leak... I just
use a good silicone... no more leaks... a 1/4" is thick
enough for what its doing... its holding up the engine
and pulls on the drivers side frame rail while pushing
down on the pass rail... dont expect it to hold the
fore/aft load of the launch... I use to use 1/4" for
a long time till I came down hard and it bent, now
I use 3/8"
