426 hemi oil squirting from rocker shaft bolts #741053
07/05/10 07:30 PM
07/05/10 07:30 PM
englewood beach, florida
ts70rt Offline OP
ts70rt  Offline OP
Help, I have a 426 hemi that lost oil pressure. I replaced the pump, checked all bearings and external oil lines. I can build 70 psi with a drill but 17 psi cranking. I notice oil squirts for the bolts that hold the rocker shafts to the stands. They are hex bolts that have lock washers under the bolt heads. Does anyone know if this is correct. Thanks for any info
Re: 426 hemi oil squirting from rocker shaft bolts [Re: ts70rt] #741054
07/05/10 08:32 PM
07/05/10 08:32 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
I don't think lock washers are used.
Re: 426 hemi oil squirting from rocker shaft bolts [Re: stumpy] #741055
07/05/10 08:47 PM
07/05/10 08:47 PM
Alone in the darkness
gamagoat6x6 Offline
super street
gamagoat6x6  Offline
super street
Yep. No washers in that application. That`s your problem.
`02 RAM2500 SPORT V10 4x4 `06 GMC sierra NO cars
