Upgrade kit for OE headlight improvement #740759
07/05/10 01:44 PM
07/05/10 01:44 PM
Hunt Valley, Maryland
1fastrunner Online work OP
1fastrunner  Online Work OP
Is there a wiring kit for upgrading OE wiring on headlights so the brightness doesn't vary with engine speed?
Thanks,
Re: Upgrade kit for OE headlight improvement [Re: 1fastrunner] #740760
07/05/10 01:47 PM
07/05/10 01:47 PM
the house on the left.
cogen80 Offline
cogen80  Offline
Thanks,
you can put relays in for them. real easy job to do. use the stock wires coming down the wheel well to trigger the relays.
Re: Upgrade kit for OE headlight improvement [Re: cogen80] #740761
07/05/10 02:06 PM
07/05/10 02:06 PM
morrisville, pa
skajm Offline
skajm  Offline
morrisville, pa
Re: Upgrade kit for OE headlight improvement [Re: skajm] #740762
07/05/10 10:39 PM
07/05/10 10:39 PM
Thanks,
I read, but I'm still a little unsure of how to correct the problem. I'm also a little afraid to mess with my wiring because of no experience.
Re: Upgrade kit for OE headlight improvement [Re: 1fastrunner] #740763
07/07/10 02:06 PM
07/07/10 02:06 PM
Danville, PA
mroup Offline
mroup  Offline
Danville, PA
I would look at www.suvlights.com. They might have a prewired kit that just plugs in so your existing wiring does not require changing.
Re: Upgrade kit for OE headlight improvement [Re: 1fastrunner] #740764
07/07/10 04:33 PM
07/07/10 04:33 PM
In the twisties
RokketRide Offline
super gas
RokketRide  Offline
super gas
In the twisties
Super easy schematic to follow:
