Brake pedal to the floor! Hissing with NO BRAKES!!
#740684
07/05/10 08:10 AM
07/05/10 08:10 AM
Posts: 1,499 Slidell, LA
Plum440
Slidell, LA
I've got power brakes on a 70' B-Body. It's a completely rotisserie restored car with everything NEW. The brake pedal is almost to the floor and the brakes are barely working. When you press on the brake you get a loud HSSSSSSsssss coming from pedal . The brake system is 100% NEW and was just bled. Could I have a faulty brake booster?? I thought that even with power brakes if the booster goes bad you still have a brake system but it's manual. This thing has NO BRAKES!!! Thanks, Steve
70 Challenger, 440, 4-speed, pLuM cRaZy 71 VW Super Beetle Convertible, Lemon Yellow A couple of Jeeps…
Re: Brake pedal to the floor! Hissing with NO BRAKES!!
[Re: Plum440]
#740685
07/05/10 08:27 AM
07/05/10 08:27 AM
Posts: 1,289 Ohio
moparrjm
super gas
super gas
Ohio
First thing is to make sure your brake shoes are properly adjusted, if they are, check for leaks, if no leaks you have a bad master cylinder.
[Re: moparrjm]
#740690
07/05/10 12:02 PM
07/05/10 12:02 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
