Light switch back feed? UPDATE
#740630
07/05/10 12:10 AM
07/05/10 12:10 AM
Posts: 862 Iowa State fan
kilroy
Iowa State fan
OK just posted about rusty fuse clips, they were pretty bad so got fixed. Now Im having a back feed issue that blows the 5amp fuse for the the dash lights then or the 20 amp park light fuse. Im also replacing some dash bulb at the moment so there are some sockets hanging empty. (no parts stores open this time of night) When I turn on the park lights everything fine as long as the dash light are turned down or off. when I turn dashes on high they light dimly and the door open/lights on buzzer makes a half sickly instead of the really major annoying buzz. The light switch has had to be jiggled to make the dashes come on for sometime. Is this a bad light switch resistor? or am I looking at something that has got grounded tonight with the tinkering?
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
Re: Light switch back feed?
[Re: kilroy]
#740631
07/05/10 09:21 AM
07/05/10 09:21 AM
kilroy
Iowa State fan
ill do more tinkering and if no one has had something like this ill let this die.
[Re: kilroy]
#740632
07/05/10 09:36 AM
07/05/10 09:36 AM
Posts: 21,123 Niles , Ohio
therocks
Niles , Ohio
If you have to play with the switch to get dash lights to work the rehoastat on it is bad or almost gone.Sometimes they can be cleaned with spray contact cleaner.The back feed might be the dash not grounded.I know a lot of the dashes need a ground to function properly.Rocky
Chrysler Firepower
Re: Light switch back feed? UPDATE
[Re: kilroy]
#740636
07/11/10 02:37 PM
07/11/10 02:37 PM
kilroy
Iowa State fan
Ok what a return home, every thing seems to have gone nuts since I got back but in the mean time got my dash lights fixed. Went and bought and new headlamp switch and installed. Was kind of annoyed as it had extra contacts and the clip hooks for the plastic bracket weren't in the same spot but it still had the other contacts in the right spots so... Ok anyways when I took the old out it looked fine but decided to replace anyways as I was out of ideas. Even though I had grounded dash to the chassis I hadn't notice that there was a ground tab on the actual switch so I hooked a ground wire up to the dash also while I was there. Reinstalled, and the damn thing didnt blow anymore fuses. So I not really for sure if it was the extra ground or the switch but neither could have hurt. Finally some closure just in case anyone was wondering.
