Superbird nose cone question #73797
06/14/08 08:55 PM
06/14/08 08:55 PM
Buzzardbreath Wyoming
BigBird Offline OP
BigBird  Offline OP
On a Superbird nose there are rubber seals that help direct the air flow to the radiator. Ok now for the question. On the diagram below where does #20 go and what does it actually look like. Also was there a big seal that goes on the bottom of the nose assembly?
Re: Superbird nose cone question [Re: BigBird] #73798
06/15/08 12:37 AM
06/15/08 12:37 AM
CO
Redbird Offline
Redbird  Offline
CO
Merl, #20 is down by the K-member. It goes over the top of the 1" wide bracket that goes from the K-member to the radiator support, on the front-tucks above the bottom edge of the radiator support. On each side there are 2 clips that hold it up to the K-member. We used to call it the "diaper". It makes changing the oil filter much more difficult.
Re: Superbird nose cone question [Re: Redbird] #73799
06/15/08 05:56 AM
06/15/08 05:56 AM
BigBird Offline OP
BigBird  Offline OP
Thanks Redbird. I was hoping someone like yourself would reply. How bad will it affect the cooling of the car if it stays out? I don't think I've ever seen one on a car but I wasn't really looking for them at the time.
