notching 727 bellhousing #737549
06/30/10 04:55 PM
06/30/10 04:55 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
There was a thread on here with pics of bellhousing notches for converter bolt access.
Could anyone either find it for me or show me a pic of there's please
Mick
Re: notching 727 bellhousing [Re: deaks] #737550
06/30/10 05:01 PM
06/30/10 05:01 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I remember seeing the post but don't know where it is
From what I've seen they cut between the 2 center cover bolts and go back about 1.5-2"
(you'll have to convert to metric yourself )
Make sure you have a generous radius in the corners.
Re: notching 727 bellhousing [Re: roadhazard] #737551
06/30/10 05:12 PM
06/30/10 05:12 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
I#ve already notched it about an 1 1/4 i want to go another 3/4, i drilled the corners with a small drill, should i increase the radius.
Mick
