Hemi oil system question #734843
06/27/10 04:08 PM
06/27/10 04:08 PM
NJ-USA
HPMike Offline OP
HPMike  Offline OP
NJ-USA
Anyone know if this setup would clear an unmodified hemi K frame and stock mounts? Can't see how it wouldn't, but just checking to see if anyone is running this setup. Can't really tell from the photos how thick the sandwich plate is?
http://chucker54.stores.yahoo.net/siliexoilkit1.html
MB
Re: Hemi oil system question [Re: HPMike] #734844
06/27/10 04:49 PM
06/27/10 04:49 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
If the pickup line comes out the front and the line comes underneath and loops up to the fitting....
No...
The Indy pump cover or even the Muscle Motors pump cover would be much better and comes out the back
IMO
I would buy the Indy pump cover, or the Muscle Motors pump cover, and the static pickup setup 440Source offers if you want to save a few bucks.
Re: Hemi oil system question [Re: Bob_Coomer] #734845
06/27/10 05:32 PM
06/27/10 05:32 PM
NJ-USA
HPMike Offline OP
HPMike  Offline OP
NJ-USA
No...
IMO
I see/work on a lot of original hemi cars and can tell you that the MM or Indy pump covers look too bulky to work-but in all honesty I have never actually tried it. The stock mount looks too close with the mass of those covers. 440 Source??, uhmm , no thanks....
Anyone with any real world installation issues to report?
MB
Re: Hemi oil system question [Re: Bob_Coomer] #734846
06/27/10 05:37 PM
06/27/10 05:37 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I don't know that the rear exit plate wold be better. With the milodon rear exit with a motor plate I had to modify the steering box bracket and then still had to find a special fitting to clear. But looking at it again that pick up plate is between the pump and the motor, my external pick up plate was bolted to the end of the pump . As I don't have any original mounts at all , I can't say I guess one way or the other. You'll also need to get a longer intermediate oil pump shaft along with that type of kit.
Re: Hemi oil system question [Re: HPMike] #734847
06/27/10 05:55 PM
06/27/10 05:55 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Hemi oil system question [Re: HPMike] #734848
06/27/10 06:48 PM
06/27/10 06:48 PM
Cab_Burge Online work
Cab_Burge  Online Work
That plate was designed to go along with the second inlet on the pump cover, the plate necks down internally to a very small area, not good on the inlet side I know guys running that system on the street and at the track, I would not trust it or use it by itself BTW, I do use it on my dual line setup on my 527 bracket motor
Re: Hemi oil system question [Re: Cab_Burge] #734849
06/27/10 07:00 PM
06/27/10 07:00 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
The front inlet sandwich plate will work with the stock mounts and is as good if not better than the stock internal pickup.The rear inlets require modifying the mount,the side will work if you also loop it to the front.Remember to use the longer intermediate shaft with the sandwich plate.You can also just buy the Milodon alum pump with the front inlet and use a stock or plugged aftermarket cover plate
Re: Hemi oil system question [Re: B G Racing] #734850
06/28/10 11:28 AM
06/28/10 11:28 AM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
i run the milodon pump with a stock cover, no internal pickup. works great and will clear stock mounts.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: Hemi oil system question [Re: 68 HEMI GTS] #734851
06/28/10 12:49 PM
06/28/10 12:49 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Sorry to stray off topic but is that a hemi block with wedge ears on a stock BB a body K ???
Re: Hemi oil system question [Re: JohnRR] #734852
06/28/10 05:38 PM
06/28/10 05:38 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
yep , sure is. lol
