Does anybody have the answer to this plug wire question #734248
06/26/10 08:00 PM
06/26/10 08:00 PM
Chilly Northern, Minn.
71 Charger R/T Offline OP
I just bought a set of tailored OEM style plug wires for my '71 Charger R/T (440 4bbl) I have searched high and low but cannot find information explaining which wires (length and boot ends) go to which cylinder. Two of the wires have straight boots on both ends, 3 are elbowed both ends, 3 are straight on cap end and elbowed on plug end. I can't even find anything in my factory service manual can anyone tell me even where I could find the info?
Thanks again in advance,
Lyndon
Re: Does anybody have the answer to this plug wire question [Re: 71 Charger R/T] #734249
06/27/10 10:22 AM
06/27/10 10:22 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
There should have been a sheet saying what length wire for which cylinder in the package ... there was in the set i bought many years ago ... call the supplier tomorrow if you can't get the answer .
Re: Does anybody have the answer to this plug wire question [Re: 71 Charger R/T] #734250
06/27/10 10:47 AM
06/27/10 10:47 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
do you have access to a fax?
I can send you a spec sheet if so
Re: Does anybody have the answer to this plug wire question [Re: gtx6970] #734251
06/27/10 05:23 PM
06/27/10 05:23 PM
Bill, You're getting to be my "go to" guy! I'll get you a fax # tomorrow (Mon.)
Thanks,
Lyndon
