Re: What waste gate?? [Re: feets] #733243
06/30/10 06:13 PM
06/30/10 06:13 PM
Iowa
76dodgeboy Offline OP
Iowa
I like the sound of a BOV . I like noisy geardrive aswell. When you drive crap like I have that rattles or whistles because of bad door seals and no radio less stuff bothers ya. Thanks
Re: What waste gate?? [Re: 76dodgeboy] #733244
06/30/10 07:54 PM
06/30/10 07:54 PM
Dirty Dena, Maryland
dodge turbo Offline
dodge turbo  Offline
yes i sent you that spacer when i sold that too you....and that is the wastegate...the bov is by the carb..
that was set up ran 7psi fine all the time with no creep at all and a masterpower 70mm turbo and that 38mm wastegate...
That H1E i sold you will fit right on there and is t-4 flanged and is about 67mm in size if a rember
78 Adventurer 150small block turbo'd 360w/Borg S475....smoke'em
Re: What waste gate?? [Re: dodge turbo] #733245
06/30/10 08:25 PM
06/30/10 08:25 PM
Iowa
Iowa
Never got that flange with it. Ill double check tomorrow but Im sure I didnt
Re: What waste gate?? [Re: 76dodgeboy] #733246
07/01/10 04:32 PM
07/01/10 04:32 PM
Iowa
Iowa
Ok I apparently never really dug throught the box Its there. So I need a 2 bolt waste gate for that piece than correct? so do I plum the exhaust tube from the wg back into the downpipe somewhere or just let it dump where ever? Thanks
Re: What waste gate?? [Re: 76dodgeboy] #733247
07/01/10 05:18 PM
07/01/10 05:18 PM
dodge turbo Offline
dodge turbo  Offline
thats a 38mm wastegate flange for a 38mm wastegate...you can plumb it into the down pipe or cut a small hole in the inner fender well or route a pipe off it to underneath the fender well and vent it
Re: What waste gate?? [Re: dodge turbo] #733248
07/01/10 06:56 PM
07/01/10 06:56 PM
Iowa
Iowa
Sweet
Re: What waste gate?? [Re: joshking440] #733249
07/05/10 02:50 PM
07/05/10 02:50 PM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Hello,
Wastegate is after the turbo. It diverts the air from the pressure side to the exhaust for overboost conditions such as limiting boost and between shifts among a couple others.
Damon
pay no attention to any advice from this guy
Hello,
Yea, I stated it incorrectly. Sorry! Was in a big hurry.
What is up your back side Josh? Thanks for the personal attack.
Damon
Re: What waste gate?? [Re: mopardamo] #733250
07/06/10 01:56 AM
07/06/10 01:56 AM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
Re: What waste gate?? [Re: 76dodgeboy] #733251
07/06/10 02:16 PM
07/06/10 02:16 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I was pretty sure its before. I ment where or how close to before the turbo.
Can be as close as you want. Some turbos have their own internal wastegate built into the exhaust housing side of the turbo.
Re: What waste gate?? [Re: DaytonaTurbo] #733252
07/06/10 07:03 PM
07/06/10 07:03 PM
Iowa
Iowa
I have a flange that it goes on. I didnt see it in the box when I got it so the location is taken care of now
Re: What waste gate?? [Re: mopardamo] #733253
07/21/10 09:24 AM
07/21/10 09:24 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Hello,
Damon
It was a response to the info you typed, not you personally. When you accidentally type incorrect info it can lead someone astray.
However, 'trust but verify' is ultimately the responsibility of the car builder. This is why I'd recommend to any newbie to buy a few books and learn the basics on their own. $75 on 3-4 books is a cheap but wise investment.
Re: What waste gate?? [Re: 76dodgeboy] #733254
01/26/11 04:37 AM
01/26/11 04:37 AM
Iowa
Iowa
Well I listed my stuff forsale as I dont believe Ill have the time to build a turbo truck and had to sell a couple trucks to downsize and save some money. Plus I dont think I could figure out how to set up the timing, ign or if I should carb or efi and from what Ive seen you guys have for a fuel system I really cant afford that but If I dont atleast get what I have in the parts Ill just hold on to it.
I have the H1E Turbo, the turbo manifold the wg Flange an intercooler, down pipe and a crossover pipe to conect both manifolds. What else would I need to finish?
Waste Gate, BOV, Carb or EFI, piping
What would be best carb or EFI and what for the fuel system and how to make it retard or advance when needed?
I really dont want to get rid of this stuff but I can find another truck cheap as I'd rather have the truck look beat for the ultimate sleeper. Any thoughts and encouragement
Re: What waste gate?? [Re: 76dodgeboy] #733255
01/27/11 04:06 AM
01/27/11 04:06 AM
Iowa
Iowa
Should I fuel inj or carb? What ign system? This will help me decide as I can finish the engine side of it and run the piping etc when I find the truck to use. Thanks
Re: What waste gate?? [Re: 76dodgeboy] #733256
01/27/11 04:25 PM
01/27/11 04:25 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Carb or EFI is personal choice and based on budget. Carb can be cheap or can be spendy. EFI is even spendier (at a minimum).
Earlier someone recommended to get a few books on turbos. Books will contain far better info than you'll get on the internet, and you can read them on the crapper to maximize your time. Fewer typos of where to mount a wastegate (and Corky Bell's book shows examples of good and bad wastegate plumbing).
Re: What waste gate?? [Re: Fury Fan] #733257
01/27/11 09:33 PM
01/27/11 09:33 PM
Iowa
Iowa
Thanks. I believe I have his book and I have another. I haven't read his yet but did some of the other.
Re: What waste gate?? [Re: 76dodgeboy] #733258
01/28/11 03:09 PM
01/28/11 03:09 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Corky's pretty downbeat on carbs, he thinks EFI is the only choice for forced induction. There is the assumption that port-EFI gives perfect cylinder-cylinder fuel distribution (which it probably can), but that's only ideal if you have perfect air distribution (which you probably won't).
Plenty of blow-thru carbs running successfully out there. Visit:
http://www.theturboforums.com/smf/index.php?board=13.0 (the blowthru carb section)
and
http://www.theturboforums.com/smf/index.php?board=21.0 (the Mopar section)
And remember, the easiest way to reach a performance goal is to pattern after someone who's already done it:
http://www.theturboforums.com/smf/index.php?topic=50928.175 (the 'builds' section)
Re: What waste gate?? [Re: Fury Fan] #733259
01/28/11 03:30 PM
01/28/11 03:30 PM
Iowa
Iowa
Thanks. My main thing is I dont understand the whole ign thing when boosted. I know there are carbs out there for boosted aps or one can be modified. Its funny that when I first got this setup everyone wanted the manifold but nobody has contacted me on it. Not a big deal to me. Thanks for the info and links. Ill try to find a book for carb apps.
Re: What waste gate?? [Re: 76dodgeboy] #733260
01/28/11 04:20 PM
01/28/11 04:20 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
'Ign when boosted' is somewhat simple. Generally you want to reduce timing when under boost, usually a few degrees per lb of boost. Look up the MSD BTM (boost timing master) for more info.
You can probably find better explanations out there, but the overview:
The burning of gasoline in a cylinder is actually a controlled burn, not an explosion as we would normally think of.
Detonation is an uncontrolled 2nd explosion in the cylinder, after the spark and from the other side of the cylinder, and the collision of the 2 flame fronts cause incredible cylinder pressure near TDC.
Detonation is a killer of boosted engines.
Hot temps, lean mixtures, hotspots, etc, can lead to detonation.
Denser mixtures require less ign advance because the flame front jumps across the fuel particles faster and in a controlled manner (ideally, anyway).
Lean mixtures have further to jump, and require more time for it, so they need more advance.
So, in a boosted engine, you have a nice dense mixture in a cylinder that is surely hotter than it was as NA, so you reduce the advance because you don't need it and you don't want it.
I saw a smallblock turbo manifold in teh Swap section recently for $350 IIRC. If that one's yours, the price may have doused people's interest in it. Although there aren't a lot of those manifolds out there and market price is hard to establish, $350 might make guys look for cheaper options. Just IMHO.
Re: What waste gate?? [Re: Fury Fan] #733261
01/28/11 05:09 PM
01/28/11 05:09 PM
Iowa
Iowa
Well considering there aren't that many and I have close to $1000 for everything listed the price for the manifold won't come down much wich is fine with me. I'm not going to loose a bunch of money. Thanks
