Smallblock in a Caravan #731327
06/22/10 03:38 PM
06/22/10 03:38 PM
salem, oregon. usa
E
elmor Offline OP
elmor  Offline OP
E
salem, oregon. usa
A few years ago, I saw a mid-80's Caravan with a smallblock/automatic in it. Anyone ever build one of these, and how much of a pain was it? I' sure I could figure out how to mount the engine, trans, and rear, but I'm concerned with front suspension.
Re: Smallblock in a Caravan [Re: elmor] #731328
06/22/10 04:22 PM
06/22/10 04:22 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
A mid engine install may be easier, and the handling might actually be better than stock!
Re: Smallblock in a Caravan [Re: Kern Dog] #731329
06/22/10 04:33 PM
06/22/10 04:33 PM
scratchnfotraction Offline
dont see hwy you cant do it
I put a 350 chebby in an astro van before
hardest thing was hacking the wire harness
and that thing would fly with 3.73 gears
Re: Smallblock in a Caravan [Re: scratchnfotraction] #731330
06/22/10 05:24 PM
06/22/10 05:24 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Problem with that is the Astro is a RWD, the Caravan is not.....
Re: Smallblock in a Caravan [Re: RodStRace] #731331
06/23/10 12:39 AM
06/23/10 12:39 AM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
And it already has a V6, so adding two more cylinders up front and switching to an electric fan is a piece of cake compared to a Caravan V8-RWD swap.
I would think a V8-RWD conversion setup for a FWD Daytona would be a good place to start.
Re: Smallblock in a Caravan [Re: In_The_Pink] #731332
06/23/10 01:17 AM
06/23/10 01:17 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
All you really need is a sawzall, a MIG welder and a tape measure, right? Men who blazed the trail back in the pioneer days are who made things happen. Are YOU that guy?
Re: Smallblock in a Caravan [Re: Kern Dog] #731333
06/23/10 03:21 AM
06/23/10 03:21 AM
salem, oregon. usa
E
elmor Offline OP
elmor  Offline OP
E
salem, oregon. usa
I've got a sawzall, and my buddy has a welding shop. The van I saw was a mid engine mount. I figure a slightly warm 360 ought to run it pretty strong. I don't think swapping in an 8 1/4 rear should be too hard. I'm concerned with transmission and driveshaft length. Need to do some measuring. Hey if I'm gonna go this far, why not a bigblock? I know where I can get a C-body 8 3/4 rear for nothing. But I digress.
Re: Smallblock in a Caravan [Re: elmor] #731334
06/23/10 08:05 AM
06/23/10 08:05 AM
I understand it is not a RWD van...I was just saying I think it could be done..
my worthless
Re: Smallblock in a Caravan [Re: scratchnfotraction] #731335
06/23/10 11:14 AM
06/23/10 11:14 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
In some ways I think the Caravan might be a little easier than the Astro.
With the Astro, it mostly bolts in but you're constrained by the close-fit OEM structure, and to R&R the engine in a van ain't easy.
But to put an engine in the middle of the cargo floor (probably have to put it right behind the front seats in order to get a driveshaft in there), in a wide-open area, thru the side door, sounds easier. If there is an extended-wheelbase model that might be the best start to get good driveline angles.
Yes, you'll have lots of engine-cradle and axle mounting fab to do, but it's a fairly blank slate without a lot of interference from existing structure. Run some 2x3 or 2x4 box tubing longitudinally and then tie front and rear framerails to it. A 4-link might be the way to go for rear suspension? A Ford Explorer 8.8 might be narrow enough.
Radiator stays up front and plumbed with extension pipes, use elec fans to cool it.
Fuel tank needs a re-lo? I presume it is currently forward of the rear axle?
The existing steering and susp would be OK, just pull the halfshafts out. You could even leave the original engine/trans in there for ballast if needed, depending on how much the mid-engine settles out. If you need less ballast, remove the engine/trans, and you have a nice hole to locate suitable ballast.
I’m thinkin’ a smallblock underneath a sturdy metal shroud, with some good insulation on top, some fake cargo covering it, would make a helluva sleeper. This is a neat idea!
And hey, if you plan it right, you might even still be able to drive it around some while you're working on it!
Re: Smallblock in a Caravan [Re: Fury Fan] #731336
06/23/10 12:11 PM
06/23/10 12:11 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
A member here used to have a 318 powered caravan. I don't have any pics or details but I'm pretty sure he used the F/M/J front suspension in it.
Re: Smallblock in a Caravan [Re: 440newport] #731337
06/23/10 01:49 PM
06/23/10 01:49 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
This one?
Re: Smallblock in a Caravan [Re: Jwilli500] #731338
06/23/10 01:52 PM
06/23/10 01:52 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
I forgot what his handle was but I think it was Minivanman or something like that. I believe he used Diplomat K-frame or something similar. These things already have leaf springs out back to hang a 8 3/4 on. Nuther pic...
Re: Smallblock in a Caravan [Re: elmor] #731339
06/23/10 02:51 PM
06/23/10 02:51 PM
St Louis, Missouri
Runnin74 Offline
Runnin74  Offline
St Louis, Missouri
I don't know about the earlier model Caravans, But the 2001 and up models have no tranny tunnel - just flat floorboards. I suppose if one was going to the effort to put in a small block that wasn't a mid mount you could graft in a tunnel.
Re: Smallblock in a Caravan [Re: Fury Fan] #731340
06/23/10 03:35 PM
06/23/10 03:35 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
It would be way easier to add the v-8 to the astro, heck they even had quadrajets on them the first year, the trans will work, and will be tight up front at water pump area, but do-able.
Re: Smallblock in a Caravan [Re: buildanother] #731341
06/23/10 04:10 PM
06/23/10 04:10 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Sure hope the caravan swapper joins in on this one, that looks neat!
Re: Smallblock in a Caravan [Re: RodStRace] #731342
06/23/10 05:36 PM
06/23/10 05:36 PM
Montana
FuryUs Offline
FuryUs  Offline
Montana
Scarevandan left moparts a while back. Not exactly sure why, but I doubt he'll chime in.
Re: Smallblock in a Caravan [Re: FuryUs] #731343
06/23/10 05:40 PM
06/23/10 05:40 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
He had a small website that I kept in my favorites but it looks like it has been taken down.
Edit:
If your serious about contacting him you might take a look at this...
http://www.moparts.org/moparts/carshow/2003/4/scarevandan.html
Re: Smallblock in a Caravan [Re: Jwilli500] #731344
06/23/10 09:00 PM
06/23/10 09:00 PM
salem, oregon. usa
E
elmor Offline OP
elmor  Offline OP
E
salem, oregon. usa
I'd sure like to see how he mounted the engine and trans, so I could duplicate it. As far as I recall, non of the mopar minivans had trans tunnels.
Re: Smallblock in a Caravan [Re: elmor] #731345
06/23/10 09:49 PM
06/23/10 09:49 PM
Florida STAYcation
BeEtLeJuIcE ! Online penguin-006
The village idiot's idiot
BeEtLeJuIcE !  Online Penguin-006
Florida STAYcation
I say just cut-the-floor out and throw in some 2x3 lots-of tubing and the HANG the body onto that.
ALSO .. move the motor WAAAY back ...and enter the van from the rear slider doors ....
Re: Smallblock in a Caravan [Re: elmor] #731346
06/24/10 06:23 PM
06/24/10 06:23 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
somone here had a van wit a SB, if i remember right he used a dipy k frame, and the rear axel.
