FUEL SYSTEM HELP MAGNA FUEL #729978
06/20/10 10:59 PM
06/20/10 10:59 PM
utica ny
meus31 Offline OP
meus31  Offline OP
utica ny
i have a magnafuel pump 300 series i installed it in the car, dash ten from the cell ,dash ten to the regulator up front. i installed a dash eight back to the cell from the pump return. i have a mallory regulator and it can not keep up with the pump the pressure is all over the place. know my question is , is the magnafuel regulator that much better that it can regulate this pump or would i just be better off run a return style regulator. what are you guys doing any help would be appretiated i only want to do this once
Re: FUEL SYSTEM HELP MAGNA FUEL [Re: meus31] #729979
06/20/10 11:29 PM
06/20/10 11:29 PM
MR_P_BODY Offline
MR_P_BODY  Offline
A retun style system will give you a better/stable
pressure
Re: FUEL SYSTEM HELP MAGNA FUEL [Re: meus31] #729980
06/21/10 01:19 AM
06/21/10 01:19 AM
I use a BG four port with my Magnafuel 300 pump, I had used it on the 275 pump also with no problems controlling the pressure . Are you using a fuel filter between the tank and the pump? If so do you know what size, in microns, the filter element is? I have heard of other peole having problems with the small Mallory reg on big volume high ptessure pumps. BTW, I plumb mine like yours
Re: FUEL SYSTEM HELP MAGNA FUEL [Re: Cab_Burge] #729981
06/21/10 08:38 AM
06/21/10 08:38 AM
NC
Badfish67 Offline
Badfish67  Offline
NC
I had the same issue even with my Magna Fuel regulator. Call Magna Fuel and tell them to send you the spring/fitting kit that will lower the pressure. I changed this in mine and the pressure went from 26# down to 21# and now I dont have any issues with the regulator pressure....and I have the Magna 500.
1967 Barracuda 360ci/727 9.723ET @139.44mph
Re: FUEL SYSTEM HELP MAGNA FUEL [Re: Badfish67] #729982
06/21/10 10:33 AM
06/21/10 10:33 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I'm using the BG 4 port with my MF 500. Only return is off he pump. No problems here. At least for now anyway
