Small Block race heads suggestion... #728701
06/20/10 01:19 AM
06/20/10 01:19 AM
Warren Michigan
tofast4you27 Offline OP
Warren Michigan
Im building a 360 race motor and would like to know what would be the best heads to put on it. Are the edelbrock heads any good compaired to all the other heads out there?
Re: Small Block race heads suggestion... [Re: tofast4you27] #728702
06/20/10 02:01 AM
06/20/10 02:01 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
what kind of hp are you wanting & how fast are you prepared to spin it?
Re: Small Block race heads suggestion... [Re: rebel] #728703
06/20/10 02:06 AM
06/20/10 02:06 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
well you can get into the 11's with just stock 2.02valve 360 heads with a little bowl blend, but like the post above whats your plan?
Re: Small Block race heads suggestion... [Re: rebel] #728704
06/20/10 02:08 AM
06/20/10 02:08 AM
Warren Michigan
Warren Michigan
well my car weighs 2700 pounds and i just want to get it in the 10's with a small block. I just really dont know what kind of heads work the best and end up buying something i will regret
Re: Small Block race heads suggestion... [Re: tofast4you27] #728705
06/20/10 02:29 AM
06/20/10 02:29 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
should be easy with that weight, set of eddys with a mild port job or RHS heads, cam in the 250 @.050 range, and at least 10.5 to 1 cr.
Re: Small Block race heads suggestion... [Re: ademon] #728706
06/20/10 02:43 AM
06/20/10 02:43 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
go with a port job on the eddies
Re: Small Block race heads suggestion... [Re: tofast4you27] #728707
06/20/10 08:40 AM
06/20/10 08:40 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Welcome to the jungle... there are multiple heads
that can get you there but the cheapest is probably
the ported Eddies.... W-2s will do it easy with port
work as would W-5s but these require a different set
of rockers(but your going to need rockers anyways)
Re: Small Block race heads suggestion... [Re: tofast4you27] #728708
06/20/10 09:05 AM
06/20/10 09:05 AM
Q
Quicktree Offline
Quicktree  Offline
Q
buy a set of indy 360-1s and be done with it for a while. plenty of room to upgrade if you want.
Re: Small Block race heads suggestion... [Re: tofast4you27] #728709
06/20/10 09:09 AM
06/20/10 09:09 AM
Colorado Springs, Colorado
Dartthunder340 Offline
I think I would go with the w2's. I really like my set. I'm just not completely sold on the Eddys. They are a nice piece and at least everything would be brand new, but I'm not to keen on having to spend more money on something new to make it minimally better. But I would also disagree with my own statement. Confused? Me too. I'm not totally sure of flow numbers but I believe Shady Dells website has good comparisons on head choices. If I was going to spend some bucks I would look at Indys over Eddies for aluminum. The 360-1 is a good start. For iron I would go w2 or RHS. I just think the w2 is hard to beat even after 30 years. If I'm way off base someone please educate me as I'm pretty new to this.
Better get inside Ma. Looks like a storm's comin'.
Re: Small Block race heads suggestion... [Re: tofast4you27] #728710
06/20/10 09:13 AM
06/20/10 09:13 AM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
Are you on a loose, or tight budget????
I would look into the rhs/indy heads.
ou812 here offers them for I think maybe 1300-1400 complete and ready to use in the chamber CC of your choice. They flow extremely well for an iron head. They're a much beefier casting than factory also and won't crack, leak at the valve cover, and take standard or a w2 header, and can be ported for more flow even. I think they flow 270cfm at .550 lift the way he offers them for the mentioned price. That's with NO porting! You can also get them in the magnum or LA style rocker bosses. same casting, different bosses used. They come with ferrea stainless 2.02 valves, beehive springs and can do a .600 lift maybe a little more.
I got them because they are a great deal and are PROVEN to cut the 10 second number on a 410 in a 3000ish lb car. Since a 360 CAN make the same power with more rpm and given the weight of your car, I would say they would do the trick for you.
These would leave you more money to throw at other things like rockers or the bottom end. In the end you can build an awesome and strong 360 for not a lot.
Re: Small Block race heads suggestion... [Re: Quicktree] #728711
06/20/10 10:33 AM
06/20/10 10:33 AM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I wish I would have gotten a set of them but at the time I just did not have the extra cash but now I wish I would have waited or done something to get them
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Small Block race heads suggestion... [Re: dusturbd340W5] #728712
06/20/10 10:34 AM
06/20/10 10:34 AM
Q
Quicktree Offline
Quicktree  Offline
Q
sell you indybrocks to the poster and buy you some
Re: Small Block race heads suggestion... [Re: Quicktree] #728713
06/20/10 10:40 AM
06/20/10 10:40 AM
Kissimmee Fl.
Kissimmee Fl.
I would but still in the same boat I dont have the extra cash
Re: Small Block race heads suggestion... [Re: dusturbd340W5] #728714
06/20/10 12:28 PM
06/20/10 12:28 PM
Q
Quicktree Offline
Quicktree  Offline
Q
don't we all know that feeling
Re: Small Block race heads suggestion... [Re: Quicktree] #728715
06/20/10 10:17 PM
06/20/10 10:17 PM
Sao Paulo, Brazil
dart_73_br Offline
dart_73_br  Offline
Sao Paulo, Brazil
So.. mainly we have this.. ordered by cost/flow (stage 3 ported)
Indy/RHS (270cfm)
Iron Ram (268cfm ??)
Edelbrock (280cfm)
Indybrock (300cfm)
W2 (hard to find) (320cfm)
Indy 360-1 (320cfm)
W5 (330cfm)
Commando Large Port (320cfm ??)
Said something too stupid here?
Re: Small Block race heads suggestion... [Re: tofast4you27] #728716
06/20/10 10:45 PM
06/20/10 10:45 PM
SoCal
Brian Hafliger Offline
SoCal
It would help to know more about the car, chassis, and components you plan on using.
That said, the best head to BOLT ON would probably be an Indy head. You may be able to use a ported eddy head and save some $$$, but hard to say with such limited info...
Brian
Brian Hafliger
Re: Small Block race heads suggestion... [Re: tofast4you27] #728717
06/21/10 07:41 AM
06/21/10 07:41 AM
San Angelo, Texas
W8n2DustU Offline
W8n2DustU  Offline
San Angelo, Texas
From my experiencce, Heads-Up and BUDGET are not allowed in the same sentence. LOL! Go with a W-5 or wait a while and save to spring for a set of W8's or W9's. You will be glad you did.
2010 Toxic Orange Challenger built by B and B Racecars! All aluminum R4/P5 engine, Proformance TH400 (3 speed) tranny, full Reid case, nodular 9" rearend, full Dragpak suspension, Protorque custom converter, BS3, PTE 85mm turbo, fire core wires, carbon doors, carbon front clip, and a whole lot more!
Re: Small Block race heads suggestion... [Re: W8n2DustU] #728718
06/21/10 07:52 AM
06/21/10 07:52 AM
united kingdom
blown360 Offline
blown360  Offline
united kingdom
Ive got a set of 59* w-9's with valves that i'd sell as im now going 48*. W9s flow around 290-300 out the box and are the lightest heads available. these would support what your trying to do as they are with no work. Only downside is you'll have to run different rockers and pushrod oiling....
Re: Small Block race heads suggestion... [Re: blown360] #728719
06/21/10 01:03 PM
06/21/10 01:03 PM
Warren Michigan
Warren Michigan
well here was my plan. I have a 72 dart all tubbed out with a 4 link. 727 with a 3800 stall and a 4.88 gear. Now for the motor i already have most of the parts for the bottom end just need to figure out what im putting on top. My original plan was about 12.5 to 13 to 1 compression, edelbrock heads with a M-1 intake. But im now thinking about some W2 heads but i dont know yet. Im on a tight buget also.
Re: Small Block race heads suggestion... [Re: tofast4you27] #728720
06/21/10 01:16 PM
06/21/10 01:16 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Give Vic a call (SST/3040),he is in Michigan,and will go out of his way to get you where you want to be.He did my Edelbrocks,and a lot of other work for me.I could not be happier with his work.574-340-1966 is his number.
