Re: Small Block race heads suggestion...
[Re: tofast4you27]
#728707
06/20/10 08:40 AM
06/20/10 08:40 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Welcome to the jungle... there are multiple heads that can get you there but the cheapest is probably the ported Eddies.... W-2s will do it easy with port work as would W-5s but these require a different set of rockers(but your going to need rockers anyways)
[Re: tofast4you27]
#728708
06/20/10 09:05 AM
06/20/10 09:05 AM
Quicktree
well my car weighs 2700 pounds and i just want to get it in the 10's with a small block. I just really dont know what kind of heads work the best and end up buying something i will regret
buy a set of indy 360-1s and be done with it for a while. plenty of room to upgrade if you want.
[Re: tofast4you27]
#728709
06/20/10 09:09 AM
06/20/10 09:09 AM
Posts: 311 Colorado Springs, Colorado
Dartthunder340
I think I would go with the w2's. I really like my set. I'm just not completely sold on the Eddys. They are a nice piece and at least everything would be brand new, but I'm not to keen on having to spend more money on something new to make it minimally better. But I would also disagree with my own statement. Confused? Me too. I'm not totally sure of flow numbers but I believe Shady Dells website has good comparisons on head choices. If I was going to spend some bucks I would look at Indys over Eddies for aluminum. The 360-1 is a good start. For iron I would go w2 or RHS. I just think the w2 is hard to beat even after 30 years. If I'm way off base someone please educate me as I'm pretty new to this.
Better get inside Ma. Looks like a storm's comin'.
[Re: tofast4you27]
#728710
06/20/10 09:13 AM
06/20/10 09:13 AM
Posts: 1,074 detroit, mi
POS Dakota
detroit, mi
Are you on a loose, or tight budget???? I would look into the rhs/indy heads. ou812 here offers them for I think maybe 1300-1400 complete and ready to use in the chamber CC of your choice. They flow extremely well for an iron head. They're a much beefier casting than factory also and won't crack, leak at the valve cover, and take standard or a w2 header, and can be ported for more flow even. I think they flow 270cfm at .550 lift the way he offers them for the mentioned price. That's with NO porting! You can also get them in the magnum or LA style rocker bosses. same casting, different bosses used. They come with ferrea stainless 2.02 valves, beehive springs and can do a .600 lift maybe a little more. I got them because they are a great deal and are PROVEN to cut the 10 second number on a 410 in a 3000ish lb car. Since a 360 CAN make the same power with more rpm and given the weight of your car, I would say they would do the trick for you. These would leave you more money to throw at other things like rockers or the bottom end. In the end you can build an awesome and strong 360 for not a lot.
[Re: dusturbd340W5]
#728712
06/20/10 10:34 AM
06/20/10 10:34 AM
Quicktree
I wish I would have gotten a set of them but at the time I just did not have the extra cash but now I wish I would have waited or done something to get them
sell you indybrocks to the poster and buy you some
[Re: dusturbd340W5]
#728714
06/20/10 12:28 PM
06/20/10 12:28 PM
Quicktree
I would but still in the same boat I dont have the extra cash
don't we all know that feeling
[Re: Quicktree]
#728715
06/20/10 10:17 PM
06/20/10 10:17 PM
Posts: 637 Sao Paulo, Brazil
dart_73_br
Sao Paulo, Brazil
So.. mainly we have this.. ordered by cost/flow (stage 3 ported) Indy/RHS (270cfm) Iron Ram (268cfm ??) Edelbrock (280cfm) Indybrock (300cfm) W2 (hard to find) (320cfm) Indy 360-1 (320cfm) W5 (330cfm) Commando Large Port (320cfm ??) Said something too stupid here?
[Re: tofast4you27]
#728717
06/21/10 07:41 AM
06/21/10 07:41 AM
Posts: 1,138 San Angelo, Texas
W8n2DustU
San Angelo, Texas
From my experiencce, Heads-Up and BUDGET are not allowed in the same sentence. LOL! Go with a W-5 or wait a while and save to spring for a set of W8's or W9's. You will be glad you did.
2010 Toxic Orange Challenger built by B and B Racecars! All aluminum R4/P5 engine, Proformance TH400 (3 speed) tranny, full Reid case, nodular 9" rearend, full Dragpak suspension, Protorque custom converter, BS3, PTE 85mm turbo, fire core wires, carbon doors, carbon front clip, and a whole lot more!
