70 AAR underneath restoration what to do??
#72619
06/12/08 10:32 PM
06/12/08 10:32 PM
Posts: 1,404 northeast ohio
hulmule
northeast ohio
trying to finish up my AAR to sell.the rear end is out and K member.I've started to wash the underside with kerosine.come to find out under the grease is the red and gray dip primer.the car had a trunk pan installed and the rest is really clean.there was black paint that was on over the primers, the center hump back to the area over the axles .I was told they never painted them, so i washed it all off.now all that is left is this dip primer.should i paint the underneath or live it the primer and pressure wash off with some type of grease remover.(grease lighting).I dont want some one to think im hiding anything, but i want it to look good. Any help??
1969 Dodge Coronet R/T Convertible 1979 LiL Red x2 2012 Yellow Jacket 2006 mega cab 1977 Trailduster 1979 Trailduster
Re: 70 AAR underneath restoration what to do??
[Re: hulmule]
#72620
06/12/08 10:55 PM
06/12/08 10:55 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
I was once told that the AAR/TAs wear painted flat black/organisol on the underside above the mufflers. I have been told on here that that is wrong. I sure would like to have seen pics and have it documented, but I guess you said its gone now. Anyway common beliefis that the entire underside was gray primer with only body colored over spray as you would expect from halfass painting the rocker panels and engine compartment. Maybe someone else can chime in, I know Troy has done extensive documentation on the T/A he built.
Careful, your character's showing!
[Re: mopar346]
#72621
06/12/08 11:02 PM
06/12/08 11:02 PM
hulmule
northeast ohio
I think theres still some left here or there but i want to clean it all off.leave it primer or paint it?i was going to leave it for the next guy to do
[Re: mopar346]
#72622
06/12/08 11:03 PM
06/12/08 11:03 PM
Posts: 27,453 So Cal
autoxcuda
So Cal
... Maybe someone else can chime in, I know Troy has done extensive documentation on the T/A he built.
Troy's T/A was always a So Cal car, basically one owner, with like 40K miles or something. He has like a thousand "before" carefully cleaned archeological type pics of his car.
And get a copy of Barry Washington's pictures from the ultra low mile Yellow T/A. Someone spray bombed the underside yellow on that car, but if you look close I hear it's very helpful.
[Re: hulmule]
#72623
06/12/08 11:55 PM
06/12/08 11:55 PM
Posts: 6,252 Zzyzx Road
beepbeep
moparts member
moparts member
Zzyzx Road
If no rust NOTHING is better than what the factory applied. No way you could ever duplicate the protection of the Randsburg electro static primer.
Wash it with a soft brush and nothing stronger than Dawn detergent.
Amazing how an unchallenged lie can become the absolute truth.
[Re: beepbeep]
#72624
06/13/08 12:36 AM
06/13/08 12:36 AM
Posts: 1,711 USA
ECS
David Walden
David Walden
USA
Mr. J, Standox epoxy primer would give it a run for it's money!! (If not exceed it's protection.) If the original stuff is still in place and well preserved, I would also say to leave it.
[Re: ECS]
#72625
06/13/08 05:35 AM
06/13/08 05:35 AM
beepbeep
moparts member
moparts member
Zzyzx Road
Doctor W.
I have no doubt that the primer is good, however why remove the factory dip and primers and expose virgin metal if you do not have to. I can see the primer going over the top of the original factory stuff if it does not clean up to ones satisfaction. In fact, that is probably what I am going to do with the Valentines day Panther Pink Challenger, except I am toying with the idea of using a UV cured primer, as it is very thin.
[Re: beepbeep]
#72626
06/13/08 10:57 AM
06/13/08 10:57 AM
Posts: 3,957 West Coast, CA
Troy
West Coast, CA
If your just going to do a "quickie" I would not do anything to the bottom. Let the next owner do it the way they want to.
Here are a few pictures of what I did.
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
[Re: Troy]
#72627
06/13/08 11:08 AM
06/13/08 11:08 AM
Posts: 907 Mississauga, Canada
KARLN
Mississauga, Canada
Troy, I'm sure you've been told but you did a fantastic job on your T/A. I hope when I'm ready to do the underside of my TA that I can count on you for your expertise.
B5 Challenger T/A
[Re: Troy]
#72628
06/13/08 11:10 AM
06/13/08 11:10 AM
Troy
West Coast, CA
The only black paint that I found was on the mufflers and on the pinch weld with overspray going back to the center of the car. With much research by myself, ECS and BeepBeep I found out that the pinch weld was painted with a brush and then sprayed black.
[Re: beepbeep]
#72631
06/13/08 11:32 AM
06/13/08 11:32 AM
Posts: 1,711 USA
ECS
David Walden
David Walden
USA
Doctor W.
I have no doubt that the primer is good, however why remove the factory dip and primers and expose virgin metal if you do not have to. I can see the primer going over the top of the original factory stuff if it does not clean up to ones satisfaction. In fact, that is probably what I am going to do with the Valentines day Panther Pink Challenger, except I am toying with the idea of using a UV cured primer.
Doctor?!? We are all in trouble now! I agree 100% Mr. J. That is why I started this at the end of my post:
"If the original stuff is still in place and well preserved, I would also say to leave it."
*You have to read everything Mr. J in order for things to make sense.*
[Re: A0M397X]
#72634
06/14/08 08:08 PM
06/14/08 08:08 PM
mopar346
Thanks for address the black out issue. I would love some under side pics sometime if you have oppurtunity.
[Re: mopar346]
#72635
06/15/08 09:46 AM
06/15/08 09:46 AM
Posts: 672 Pennsylvania
A0M397X
Pennsylvania
I took a few pictures while it was up in the air. I will try to post.
No TV Party Tonight
[Re: A0M397X]
#72636
06/15/08 09:51 AM
06/15/08 09:51 AM
A0M397X
Pennsylvania
I don't know how to post more than one picture per reply. Anyway, another
No TV Party Tonight
[Re: A0M397X]
#72637
06/15/08 09:59 AM
06/15/08 09:59 AM
A0M397X
Pennsylvania
Here is an example of the overspray
No TV Party Tonight
