UPPER rad hose collapsing- 440 #724597
06/14/10 09:57 PM
06/14/10 09:57 PM
Canada
CrAzYMoPaRGuY Offline OP
Canada
I've seen a lower rad hose collapse, I've seen the results of lower rad hoses collapsing due to lack of an internal spring in a lower hose, but an upper hose?
I've heard of two upper hoses collapsing on 440 cars in less than one hour, both on an Interceptor mailing list I am on....
Is it common for an upper hose to collpase on a 440? I've never seen it happen myself- maybe with the engine shut down, but not running...?!?!
CrAzYMoPaRGuY
Re: UPPER rad hose collapsing- 440 [Re: CrAzYMoPaRGuY] #724598
06/14/10 10:03 PM
06/14/10 10:03 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
That's related to a bad radiator cap, or the wrong type.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: UPPER rad hose collapsing- 440 [Re: hemi71x] #724599
06/14/10 11:23 PM
06/14/10 11:23 PM
Canada
Canada
I sorta thought maybe it was when they shut down their engines and the coolant was TRYING to pull in from an overflow, but one says it was while his engine was running...
Never seen it! I just wonder if others have, and what causes it. Rad cap would make sense if it's after the car has been shut off, I guess running too if it's a cap for a return system or something....?
CrAzYMoPaRGuY
Re: UPPER rad hose collapsing- 440 [Re: CrAzYMoPaRGuY] #724600
06/14/10 11:48 PM
06/14/10 11:48 PM
Badham Co.
Y
Y3 70 BEE Offline
Y3 70 BEE  Offline
Y
Badham Co.
Do you have a overflow bottle? If you do make sure it has a vent and it is not clogged.
Re: UPPER rad hose collapsing- 440 [Re: Y3 70 BEE] #724601
06/15/10 01:09 AM
06/15/10 01:09 AM
Canada
Canada
They aren't my cars, as I said I've never even seen it.
I can ask though...
CrAzYMoPaRGuY
Re: UPPER rad hose collapsing- 440 [Re: CrAzYMoPaRGuY] #724602
06/15/10 09:57 AM
06/15/10 09:57 AM
Andrewh Offline
Andrewh  Offline
the only other thing might be electric fans?
The temp gets cold enough the thermostat slams shut and the fan is still going? would act like a car turned off getting too much cooling.
Re: UPPER rad hose collapsing- 440 [Re: Andrewh] #724603
06/15/10 09:39 PM
06/15/10 09:39 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
Overflow, agreed.
For collapsing hose try hard aluminum tubing , then use the radiator hose for ends with clamps. Also flex metal hose has been seen. These use rubber collars with clamps at ends. The metal hosing won't collapse.
