trans cooler hookup? #724265
06/14/10 02:59 PM
06/14/10 02:59 PM
crlush Offline OP
crlush  Offline OP
Was wondering when installing an aftermarket cooler with the stock radiator cooler witch would you run through first. Someone told me to run through aftrmarket cooler first then through the stock radiator cooler, reson being if the auxilary cooler cools the oil too much then the stock radiator cooler will then heat it back to operating temp. Makes sence too me, but would like to hear your opinions, thanks
Re: trans cooler hookup? [Re: crlush] #724266
06/14/10 03:08 PM
06/14/10 03:08 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
The other benefit is the radiator does not take the full brunt of the heat first, leaving more cooling available for the engine.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: trans cooler hookup? [Re: crlush] #724267
06/14/10 03:11 PM
06/14/10 03:11 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
Is it even possible to cool the tranny fluid down too much? I've always been told to run the biggest tranny cooler possible.
Re: trans cooler hookup? [Re: crlush] #724268
06/14/10 03:25 PM
06/14/10 03:25 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Radiator cooler to aux cooler. That is how it was OEM and worked then and still does.
